Traction digs too well
/ digs too well
i'm running with a box scraper on the back and i go through the sand without a problem. the weight made all the difference.
/ digs too well #22
Sounds like you are on the right track to solve your issue. Very nice looking tractor by the way.
If you were to pull the FEL you will fine it would be awesome handling the box blade I expect but if you are using the box blade then the FEL may be handy at the same time. :)
Light duty after market FEL's seldom have a sub frame to the rear axles which often permits the design to move the weight of the FEL 12" or so towards the rear tires. Filled tires and rear wheel weights are two things most any tractor without a backhoe needs.
When you talk about getting suck in our clay you are talking about WATER but that is not your problem. We would call getting suck in sand getting 'hung' since there is no water involved. :) Wide as possible tires would be a plus in loose sand but not cost effective except at the time of purchase.
It will just take some practice and try to keep the nose pointing down as much as possible when working even if it means driving in loops to get to the high point.
429835 (A61166)
429835 (A61166)
2023 Deere 325G (A60462)
2023 Deere 325G...
3142 (A63117)
3142 (A63117)
2 Rolls of Screen (A62613)
2 Rolls of Screen...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A63688)
2021 Unverferth...
2022 Case 5550 Trident Spreader LOW HOUR (A63688)
2022 Case 5550...
