Diggng Sewer Pipe?
/ Diggng Sewer Pipe? #31
You could always get a couple of 3/4" sheets of plywood and place them over the tank. This would distribute the load a lot better from the tires and stabilizers.
/ Diggng Sewer Pipe? #32
we had some work done on our system a few years back. due to space constraints, the contractor had to run his mini-excavator (JD 26G; probably weighs 2x-3x what the B weighs) over sensitive areas of our system.
naturally the tracks distribute the load better than tires, but he also put down steel plating to distribute the load. said it's his common practice for additional precaution. i couldn't help but be a bit concerned but he was confident and does this kind of work all the time. everything turned out fine.
large steel plate might not be in your barn, but i'd probably put down some timbers (as another member mentioned) and plywood if i was doing much more than just passing over the area.
/ Diggng Sewer Pipe? #33
Indian MC, if you can locate the end of the septic tank closest to your house and dig right at the edge of the concrete (tank) you may very likely find your problem. Often a tank, or the line will settle and separate right at the tank. Many times the drains get slow but still work, then finally some paper, or a bit of more settling causes a stoppage.
Even if you had to dig by hand it's not that much work for that small area. May save you a lot of grief. The fix is easy, once you locate the problem.
I also would not put my tractor on the tank. I had a tank lid fall in. It had been in the ground for 30 years. Had decorative rock around it with some landscaping chips on the actual lid. It was concrete! It had never even had a push mower on it, since there was no grass!
I also used my backhoe to set on the side of another tank that failed because a guy hauling water got too close and clean the concrete out of it.
/ Diggng Sewer Pipe? #34
Indian MC, if you can locate the end of the septic tank closest to your house and dig right at the edge of the concrete (tank) you may very likely find your problem. Often a tank, or the line will settle and separate right at the tank. Many times the drains get slow but still work, then finally some paper, or a bit of more settling causes a stoppage. <snip> it.
Exact thing happened to me.
Ok, sounds good... I'll play it safe. I'm not going to set the tractor square above the tank.
I'll start along the side at the inlet pipe to the tank.
It just sucks having the tractor tucked close to the side of the house.
Also,, in front of the Porch.
I'll only be able to dig diagonally and have to toss the material directly up against the porch.
If I don't toss it at the porch, tossing on top of the tank is the only other option.
On top of the Tank? I would have to ride above the tank to later remove it anyway.
The tank is 3' plus below surface to the top. The pipe must be close to 4' below surface.
I'm sure to make a mess.
Hey,,, It's one step above digging by hand! :)
/ Diggng Sewer Pipe? #36
You don't need to be on your tank to remove material you locate there when digging. You do have a backhoe, don't you? Just reach over and gently curl your bucket and put the material where you need it.
If you're fairly new and inexperienced keep the tractor engine idled down to give you better control. Don't try to dig with your machine all the way to the pipe you're looking for. Take off a foot of dirt (if you're sure it's greater then 3' down) then probe with a rod to try to feel the pipe. When your rod hits the pipe you will feel and probably hear a hollow sound. If at first you don't find the pipe take a bit more material off. Don't get in a hurry. Then probe again. When you're within a foot of the pipe finish locating it with a shovel. That will save you any grief caused by the flick of your hand!!
/ Diggng Sewer Pipe? #37
That there is some good advice..
/ Diggng Sewer Pipe? #38
I agree, 100%. Any of us doing construction/utility work do exactly this and maybe even more hand digging and probing depending on what you are looking for or digging up. If you are digging on a 24" 1200# coated natural gas line you are doing a lot of probing and shoveling as to not damage coating or worse, the pipe.
Good luck with the repair.
/ Diggng Sewer Pipe? #39
I would think you are safe to lay the dug dirt on the septic tank. Would suggest you pay plywood where ever you will dump it to protect the grass when you move it.
Will say this, if those of us who said stay off or place something over it to spread out the load are wrong then we made the digging some harder for you. If those who said we are wrong prove to be wrong...will be a mess. Heard a contractor tell about a concrete tank here the lid deteriorate in about 5 years and fell in the tank. He was called asking on the warranty on the tank is how he knew about it. To me the reward verses the risk is just not worth it.
/ Diggng Sewer Pipe? #40
Your lucky if you have 3 feet of fill over your tank. 3 feet is deep for a septic tank, usually they only have about 12-16" of fill over them.
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
2018 Buick Encore SUV (A59231)
2018 Buick Encore...
2014 Audi Q7 AWD SUV (A59231)
2014 Audi Q7 AWD...
2012 MACK CHU (PINNACLE) (A60736)
2012 MACK CHU...
2014 FORD F-450 XL SUPER DUTY SERVICE TRUCK (A59823)
2014 FORD F-450 XL...
2003 MAC TRAILERS 45' WALKING BOTTOM TRAILER (A60430)
2003 MAC TRAILERS...
