Digging up a dead horse to kick again....Cub Cadet Drive System Fluid Plus x-ref
   / Digging up a dead horse to kick again....Cub Cadet Drive System Fluid Plus x-ref #11
You CAN find full synthetic a little cheaper than that. My latest car, 2009 Cadillac, requires synthetic (it has a Mobil 1 emblem on the filler cap) and I almost choked when I used a $30 OFF coupon from the selling dealer. Previously they charged me $39 for an oil change (7.5 quarts plus filter) on my 2000 which used regular oil. I gave then the $30 coupon and was told that the balance was $55. After that I went to Walmart and bought 2 5-qt Mobil 1 jugs for $21 each figuring I would get 2 oil changes for $42. I think it went up a couple dollars now but is still much cheaper than Drive System Fluid Plus. I haven't gotten up the courage yet to try something else. I found if I jack up the front of the tractor and replace the filter really fast I lose about a pint of oil.
Bob B.
Here is the email reply I received from Mystik Lube:
If your equipment is under warranty, it is usually best to use the fluid recommended in the owner's manual. The Mystik JT-8 Synthetic Blend SHD 15W-40 Engine oil appears to be a similar fluid and should work well. You can order it at Home page or find a local distributor or retail outlet at this site.
Thanks for contacting Mystik Lubes,
Lubes Answer Line
   / Digging up a dead horse to kick again....Cub Cadet Drive System Fluid Plus x-ref #13
Lubes Answer Line
Their price is $29.10/gal. If you buy a case of 4 gal you save 2 cents. I don't know if the $12 savings is worth taking a chance or not. Walmart has 5 qt jugs of Mobil 1 available for $22 through Aug 5th. That would be less than half Cub's price.
Bob B.
New Wolverine 72in Skid Steer Brush Cutter (A59000)
New Wolverine 72in...
2007 Sterling L9500 National Crane 1800 40 Ton Tri Axle Telescopic Crane Truck (A55973)
2007 Sterling...
2013 PETERBILT 389 (INOPERABLE) (A55745)
2013 PETERBILT 389...
2014 International Maxxforce DT (A53317)
2014 International...
2019 Freightliner Derrick Digger Truck (A55973)
2019 Freightliner...
VERMEER FEED ROLLER (A58214)
VERMEER FEED...
