Digging up a dead horse to kick again....Cub Cadet Drive System Fluid Plus x-ref
   / Digging up a dead horse to kick again....Cub Cadet Drive System Fluid Plus x-ref #11
You CAN find full synthetic a little cheaper than that. My latest car, 2009 Cadillac, requires synthetic (it has a Mobil 1 emblem on the filler cap) and I almost choked when I used a $30 OFF coupon from the selling dealer. Previously they charged me $39 for an oil change (7.5 quarts plus filter) on my 2000 which used regular oil. I gave then the $30 coupon and was told that the balance was $55. After that I went to Walmart and bought 2 5-qt Mobil 1 jugs for $21 each figuring I would get 2 oil changes for $42. I think it went up a couple dollars now but is still much cheaper than Drive System Fluid Plus. I haven't gotten up the courage yet to try something else. I found if I jack up the front of the tractor and replace the filter really fast I lose about a pint of oil.
Bob B.
Here is the email reply I received from Mystik Lube:
If your equipment is under warranty, it is usually best to use the fluid recommended in the owner's manual. The Mystik JT-8 Synthetic Blend SHD 15W-40 Engine oil appears to be a similar fluid and should work well. You can order it at Home page or find a local distributor or retail outlet at this site.
Thanks for contacting Mystik Lubes,
Lubes Answer Line
   / Digging up a dead horse to kick again....Cub Cadet Drive System Fluid Plus x-ref #13
Lubes Answer Line
Their price is $29.10/gal. If you buy a case of 4 gal you save 2 cents. I don't know if the $12 savings is worth taking a chance or not. Walmart has 5 qt jugs of Mobil 1 available for $22 through Aug 5th. That would be less than half Cub's price.
Bob B.
excavator trenching bucket- one bucket per lot (A56435)
excavator...
2022 Horizon (A55973)
2015 Haulotte 5533A (A53316)
2015 Haulotte...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2010 GMC Acadia SL SUV (A56859)
2010 GMC Acadia SL...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
