Digging trench for PVC water line, advice on potential obstacles
   / Digging trench for PVC water line, advice on potential obstacles
I can’t understand why you wouldn’t start at the pump house, or somewhere outside,
On the supply line to the house?
Starting under a house, just to take the water outside, is a whole lot harder, and will yield a less satisfactory result, in the form of lower pressure/volume.
Use 3/4” schedule 40, and be sure to secure the spigot so it can’t move. Also, be sure it has adequate drainage from the fitting on the bottom.
Pressure tank is in the basement of the house. Anything upstream of that isn't under pressure unless the pump is running. No place to tap into outside the house.
This is for filling water bowls and cleaning a 35 gallon duck pond. Simply wanting to get our current solution of a 100' garden hose out of our way. No mission critical requirements, other than, turn it on an water comes out at a reasonable rate to fill some bowls and wash down the pond plastic liner.
   / Digging trench for PVC water line, advice on potential obstacles #52
I use this for running pipe underground. Removed the foot, drilled a hole and added some metal straps to connect the pipe. Of course you have to dig out the ends of the run for the pipe (I have used PVC but flexible pipe would be even easier). When done run tractor over it and for the most part there is no back fill.
Lou
   / Digging trench for PVC water line, advice on potential obstacles #53
Lou
You make it sound easy but I don't fully understand the process. Can you be more specific?
   / Digging trench for PVC water line, advice on potential obstacles #54
So I use the backhoe to dig out 8 feet at each end of the trench (because I was using 8 foot pieces).
This works best with a helper.
Run the trencher through a couple times just to break things up a bit if needed (I hit some hard pan on my last one and ended up having my helper stand on the trencher).
Connect a piece of pipe to the trencher at one end of the run.
Helper can let the operator know when to stop and glue on the next piece of pipe.
As mentioned I think this would work great with a spool of flexible pipe but I haven't tried it.
Also when you get near the end you may need to turn the tractor around (if close to building or some object you don't want moved), flip over the pipe connector on the trencher and backup.
It is easy and fast. The longer the run, the more time saved versus using a backhoe.
On my last install I connected 2 pipes to the trencher. One for electrical and one for water (I believe code says to put electrical on top, at least that is the way I did it).
Lou
   / Digging trench for PVC water line, advice on potential obstacles #55
Ok,I get the picture.😉
   / Digging trench for PVC water line, advice on potential obstacles #57
   / Digging trench for PVC water line, advice on potential obstacles #58
75 feet? Just dig the whole thing with a shovel. Problem solved. Your welcome. I wouldn't hook a backhoe up for 75' of foot deep ditch. I could be done before you got back from the shed.
Just about the funniest post I've ever read. Only on sand dude. We just had dug 200 foot trench to put in new power to my daughter's new house, 50 feet of it met the water line so dual purpose. The pulled out rock as big as the 16 inch backhoe. 100 to 150 pounds. Ain't shoveling here more than a few inches.
   / Digging trench for PVC water line, advice on potential obstacles #59
Ya, id like to see someone dig 75 foot x 24” deep by hand in my rock heaven where I live. I pull out boulders.
   / Digging trench for PVC water line, advice on potential obstacles #60
Even in just hard dirt that would be a brutal job. Way more work than I’m going to do when I could do that in less than 30 minutes with my mini x or trencher. The OP is in Georgia though. He’s probably going to burry the line 6” deep and the soil is sandy so that’s probably doable.
2017 Ford F-550 Stellar EC5000 2.5 Ton Crane Service Truck (A53422)
2017 Ford F-550...
2007 Saturn Sky Convertible Coupe (A55853)
2007 Saturn Sky...
Hose Reel (A53424)
Hose Reel (A53424)
Case 1845C (A47477)
Case 1845C (A47477)
2015 Ford F-250 (A53314)
2015 Ford F-250...
2015 Toro Workman MD Utility Cart (A55787)
2015 Toro Workman...
