Digging trench for PVC water line, advice on potential obstacles
   / Digging trench for PVC water line, advice on potential obstacles #31
75 feet? Just dig the whole thing with a shovel. Problem solved. Your welcome. I wouldn't hook a backhoe up for 75' of foot deep ditch. I could be done before you got back from the shed.
Depends on the soil conditions.
I had 33' of trench 2' deep to dig. Took 3 days working all day long in the summer with a pick and shovel. Wife decided I needed a backhoe. The backhoe was cheaper than a hospital bill. (I checked rental costs and the backhoe paid for itself in just a week or two and I still have it)
   / Digging trench for PVC water line, advice on potential obstacles #32
There are areas of black clay in Texas that is impossible to push a garden shovel into when dry then sticky than bubble gum when wet. Every year during dry summer months the county get's unimproved roads smooth enough only traction limit's how fast you can drive down them(smoother than many paved roads in the area). During winter wet season more than a few hired hands and greenhorn farmers rip fenders off tractors from mud balling up on same roads. While using a hoe when wet more wear is caused from shaking caked dirt out/off bucket than while filling bucket. Hand dig more than a few feet of ditch? i think not.
   / Digging trench for PVC water line, advice on potential obstacles #33
Yea digging 75 foot of ditch through most soils is by hand laughable. Getting it done before I could have my excavator there is even more laughable. The OP is in Georgia where I presume the soil is sandy and the frost line isn’t very deep but that’s still more work than I’d want to do.
   / Digging trench for PVC water line, advice on potential obstacles #34
Unless the distance is pretty short I never use less than 1" pipe. Difference between 3/4 and 1 is nominal. I do lawn sprinkler the same way main lines all 1" and do a return loop to equalize pressure throughout. Friction is the big capacity robber.
Ron
   / Digging trench for PVC water line, advice on potential obstacles #35
I'm going to be tapping into my house's cold water line, coming out through a foundation wall, and then making my way to our chicken and duck pen, which is about 75' away. About 30' to one side of where I will trench are a buried 240v line, telephone, and a copper propane feed. I have a good handle on where those are.
What I don't have a handle on: My 1" well line and well power line are somewhere in the area, but I don't know exactly where (house was built 20 years before I bought it, no diagram available). I can get a little insight from the inside of the basement, because I know where the well lines come into the house, but what they are doing outside the foundation, I have no idea. In places where I know I'm clear, I'll use my tractor mounted backhoe. But for places where I think the water line might be, I'm thinking I should dig by hand. I also have a handheld metal detector, was planning to scout with it. It won't penetrate deep enough to find a properly deep well power cable, but as I dig, I figure I can stick it in the trench before digging deeper.
I'm in GA: Our frostline is almost non-existent, so I'm only going down a foot, will be using either 1/2 or 3/4" PVC, terminated at a freeze-proof spigot inside the fence of the animal pen.
Any tips or tricks appreciated.
Many people don't know that companies can "subscribe" or "not subscribe" to the 811 program. If they have underground lines but don't subscribe, those lines won't be marked. And usually any homeowner or contractor installed lines won't get flagged either.
Is your well line PVC or galvanized? I said earlier I commonly trench thru PVC lines then repair them, but old galvanized lines can be a bear to repair. I'd do everything possible to not damage a galvanized underground water line.
I recently installed a 1000’ water main in a rocky central Texas hill country. I went down 2-4’ since I also added electric to the ditch. Here’s some recommendations:
- put your water line in a conduit. We’ll worth the added expense if you ever need to replace it. It’ll protect it from ground movement and drive over damage
- use a PEX line and upsize it to the next higher dimension. PEX is measured differently than PVC or copper. PEX will not crack it it freezes; it expands and returns to normal size after
- add a 12 gauge trace wire accessible on both end in case you ever need to find it
- add an extra conduit line in case you ever need to add another line, like electrical. Better to dig once
Enjoy!
   / Digging trench for PVC water line, advice on potential obstacles #36
I can’t understand why you wouldn’t start at the pump house, or somewhere outside,
On the supply line to the house?
Starting under a house, just to take the water outside, is a whole lot harder, and will yield a less satisfactory result, in the form of lower pressure/volume.
Use 3/4” schedule 40, and be sure to secure the spigot so it can’t move. Also, be sure it has adequate drainage from the fitting on the bottom.
   / Digging trench for PVC water line, advice on potential obstacles #37
I have yet to try it, but have heard that a strong pressure washer can trench, without cutting lines. If you have some vague idea of location, this might be worth a rental. ( and a full hazmat suit with eye protection)
   / Digging trench for PVC water line, advice on potential obstacles #38
That sounds like an awful mess. I don’t see it removing the mud from the trench either.
   / Digging trench for PVC water line, advice on potential obstacles #39
I have seen it work on a slope where the mud can run out the end of the trench. And it is very messy, be sure to wear some protection, maybe not a full hazmat suit, but most of it and definitely eye protection.
I would use it when I got near the pipes/conduit but not the full trench. I've used the backhoe to dig a pit near the trench to drain the water in the trench.
   / Digging trench for PVC water line, advice on potential obstacles #40
Running the risk that this should be a new thread . . .
I have a similar task to do, except mine is a new 1-1/2" supply line from well shack to the house.
What material do you use to seal around the water line where it breaches the foundation?
I have a century plus home with a stone foundation. While that will make the drilling process interesting I am assuming the material to seal between the new poly line and the foundation wall will remain the same.
Thank you for your replies.
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
2022 Coras Predator Steel End Dump Trailer (A56438)
2022 Coras...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A56438)
2020 Westfield MKX...
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2021 CATERPILLAR...
2005 MACK CV713 TRI AXLE 16FT DUMP TRUCK (A59575)
2005 MACK CV713...
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A56436)
Bulk Lot of over...
