Digging out concrete
/ Digging out concrete #1
kub1
I need to remove some small chunks of concrete that were poured around fence posts that have rotted off. They are about 18" deep and just below ground level. Is there a way I can use my small tractor with a loader to remove them? Thanks for any comments. :)
/ Digging out concrete #2
corner of the bucket might make em pop out depending on how wet the soil is, otherwise dig around them a bit with a shovel and chain onto them, pull em out slowly.
when i did fence install and removal we would use the post hole diggers and dig a hole right next to the concrete and push the post into the ne hole and pull them out.
/ Digging out concrete #3
Easy and quick with my BX23
2005 MACK GRANITE CV713 T/A DUMP TRUCK (A64276)
2005 MACK GRANITE...
(APPROX. 450')LOT OF LATCH LOCK 6" IRRIGATION PIPE (A64278)
(APPROX. 450')LOT...
TAYLOR S/A LOOSE LEAF TRAILER (A64278)
TAYLOR S/A LOOSE...
JCB 3TS-8T TELESKID SKID STEER (A65053)
JCB 3TS-8T...
10000LBS Two Post Automotive lift (A64194)
10000LBS Two Post...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
