Digging frozen ground
/ Digging frozen ground #1
B7500
Platinum Member
Tupper Lake, NY
Kubota B7500 HSD
With the winter coming upon us I was wondering if my new B7500 BH will be able to dig into frozen ground. Anyone ever tried?
-Terry
/ Digging frozen ground #2
Guess the answer depends on how deep the ground is frozen. I have seen full size backhoes that have "frost" buckets. They weld a single tooth on the back (curved) side of the bucket. This is concentrates all the curl force on a single tooth and helps break through the frozen layer. Once you break the surface the rest comes up easily. If you're talking about the end of a cold winter where the soils frozen for the top two feet I think you're out of luck.
2015 K and K Systems Towable Solar Arrow Board (A61572)
2015 K and K...
2012 John Deere 6430 102HP Agricultural 4WD Tractor (A61572)
2012 John Deere...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
E-Z TRAIL HEADER CART (A63291)
E-Z TRAIL HEADER...
2012 Allmand Bros. Maxi-Lite SHO-HD Light Tower 20KW (A63689)
2012 Allmand Bros...
2347 (A64281)
2347 (A64281)
