differential oil
/ differential oil #1
bobcat7532010
What kind of oil is used in the front & rear differential in the Toolcat cant seem to find it in the book.
/ differential oil #2
If you have a "D", the Special Sauce is designated on page SPEC-7 in your Op & Maint. Manual.
5.54 qt. (each transaxle) of p/n 6687120.
/ differential oil
Do not have the manual so what # is it?? 5600 toolcat
/ differential oil #4
bobcat7532010, let me clarify...I have a Toolcat 5600. It is the "D" variant (started production in 2007). My manual is for the "D" version. (The differences between the 5600 "A", "B", "C", and "D" variants can be found within this forum; however, if you have independent coil suspension on all four corners you have a "D".)
/ differential oil
From what I was told that the oil was all the same. Dealer does not know either. Had to order the oil from dealer but would like to know what weight of oil it takes>>
/ differential oil #6
Unfortunately, the bottle is pretty boring...no viscosity info...just a blurb on how the fluid will retain your Bobcat warranty...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59575)
2020 INTERNATIONAL...
3ft. 5-Point Metal Star (A61569)
3ft. 5-Point Metal...
KMC 216-18' HEAVY DUTY ROTOTILLER (A62130)
KMC 216-18' HEAVY...
2004 John Deere 4720 (A60462)
2004 John Deere...
New Holland 354 Feed Grinder (A64047)
New Holland 354...
2023 John Deere 333G for Parts (A61306)
2023 John Deere...
