differential oil
   / differential oil #1
bobcat7532010
What kind of oil is used in the front & rear differential in the Toolcat cant seem to find it in the book.
   / differential oil #2
If you have a "D", the Special Sauce is designated on page SPEC-7 in your Op & Maint. Manual.
5.54 qt. (each transaxle) of p/n 6687120.
   / differential oil
Do not have the manual so what # is it?? 5600 toolcat
   / differential oil #4
bobcat7532010, let me clarify...I have a Toolcat 5600. It is the "D" variant (started production in 2007). My manual is for the "D" version. (The differences between the 5600 "A", "B", "C", and "D" variants can be found within this forum; however, if you have independent coil suspension on all four corners you have a "D".)
   / differential oil
From what I was told that the oil was all the same. Dealer does not know either. Had to order the oil from dealer but would like to know what weight of oil it takes>>
   / differential oil #6
Unfortunately, the bottle is pretty boring...no viscosity info...just a blurb on how the fluid will retain your Bobcat warranty...
2021 CATERPILLAR 416 BACKHOE (A50458)
2021 CATERPILLAR...
2015 Kenworth T400 T/A Vactor 2100 Combination Sewer Jetter Vacuum Truck (A50323)
2015 Kenworth T400...
COIL TUBING FRAME (A50854)
COIL TUBING FRAME...
Unused Delta Crash...
2025 LandHonor LHR-CIA200 200lb Cast Iron Anvil (A49461)
2025 LandHonor...
2012 VOLVO VNL TANDEM AXLE SLEEPER (A51222)
2012 VOLVO VNL...
