Differential oil 90W suitable forfront axle ?
   / Differential oil 90W suitable forfront axle ? #1
dennis52
Queensland Australia
Kioti DS4510HS , Kubota B7100
The manual for my 2011Kioti DS4510 specifies 90W gear oil. I already have some fresh 90W differential oil (rated GL 5).
Is it ok to use instead of what is labelled as "Gear Oil"
   / Differential oil 90W suitable forfront axle ? #2
Yes, there are gears in a differential so it's the same lubricant. GL5 is a pretty common gear oil, I use GL5 in all my axles: tractor, jeep, 3 axle truck, etc.
Thanks. I wasn't sure if oils sold as differential oils might contain additives harmful to any parts in a tractor front axle
   / Differential oil 90W suitable forfront axle ? #4
Yes, same thing by a different name.
Chris
UNUSED LANDHONOR LDH-FPR36 - 36" FIRE PIT RING (A54757)
UNUSED LANDHONOR...
AT 26in x 11-12in (A52377)
AT 26in x 11-12in...
14' Bi-Parting Gate (A50120)
14' Bi-Parting...
UNUSED DIGGIT 6' HIGH FENCING - 1 ROLL (A54757)
UNUSED DIGGIT 6'...
WB Mower (A50120)
WB Mower (A50120)
