Differential oil 90W suitable forfront axle ?
   / Differential oil 90W suitable forfront axle ? #1
dennis52
Queensland Australia
Kioti DS4510HS , Kubota B7100
The manual for my 2011Kioti DS4510 specifies 90W gear oil. I already have some fresh 90W differential oil (rated GL 5).
Is it ok to use instead of what is labelled as "Gear Oil"
   / Differential oil 90W suitable forfront axle ? #2
Yes, there are gears in a differential so it's the same lubricant. GL5 is a pretty common gear oil, I use GL5 in all my axles: tractor, jeep, 3 axle truck, etc.
Thanks. I wasn't sure if oils sold as differential oils might contain additives harmful to any parts in a tractor front axle
   / Differential oil 90W suitable forfront axle ? #4
Yes, same thing by a different name.
Chris
SKID STEER FORKS (A53843)
SKID STEER FORKS...
LOT LOCATIONS (A54313)
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
UNUSED SWICT 84" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 84"...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2019 MACK PINNACLE P164T DAYCAB ROAD TRACTOR (A51406)
