Differential lock/4x4
/ Differential lock/4x4 #21
<font color=blue>No one else look cuz it is not about tractors</font color=blue>
In other words, you wanted to be darned sure we all looked./w3tcompact/icons/wink.gif
Would you just look at Bird's signature!!! Man that is a beauty!
Harv, I think that Bird has upped the bar and it is not like you to leave this sort of thing alone. (just trying to get a little game of "Who's got the best sig" going)
/w3tcompact/icons/frown.gif I don't even have a sig!/w3tcompact/icons/frown.gif
/ Differential lock/4x4 #24
bird that is a beautiful signature. how do u do that? not only a tractor expert but also a computer wiz.
/ Differential lock/4x4 #25
Funny thing, the whole reason I got into this RC hobby was to fly biplanes. Been into planes since 1986 and have yet to get one. I think all the moving around gets in the way. Well now thanks to ARF's and since I seem to have little time to build I'm gonna get a Kyosho Super Stearman and throw an OS .52 four stroke in it. Ought to be fun!! That plane there looks like it would be a little hottie to fly. Staggerwings sure are unique. I actually still have a Pitts in a box that I bought in 1986 and maybe after the Stearman and my youngest gets into school I'll give it a shot. I hear the Pitts can be a real hand full. Now as far as flying the real thing, I don't think so!!!/w3tcompact/icons/shocked.gif
Jeff
/ Differential lock/4x4 #26
Well Kubotadriver, your ahead of me, I've never even used the yellow dot faces that you have displayed. I havent figured out how to make a signature, heck, all I have ever done is post some pictures, Rat...
The yellow dot faces are super easy, Rat. When you get to a spot that you want one then go up to the top right of the "Reply To" page (this is the page that you type on) and open up the FAQ page in a new window and you will see all the smiley faces you can use at about the 1/3 page mark. Just cut and paste the letters and brackets next to the one you want and bingo/w3tcompact/icons/smile.gif there you are.
/ Differential lock/4x4 #28
Man, I never thought of cut and paste...I always just looked and typed. You learn something new everyday!
Jeff
/ Differential lock/4x4 #29
Bird,
This will sound like a newbie question, but why should 4X4 not be used on a hard surface? (Not that I'm planning on it, I just want to know why).
Thanks,
Chris
/ Differential lock/4x4 #30
Climber,
Just like a truck in 4wd. Hard surfaces are hard on the tires and differential. With my Ram pickup, I've felt the front end lock up slightly and the front tires are pushed on dry pavment. Feels very wierd. So, I've learned to be carefull on dry pavement with my truck.
With a tractor, I believe it's even tougher. You can feel the tractor lug somewhat when making a sharp turn on hard pavement. I usually notice this after my wife or daughter drives the JD. The 4wd lock is located on the left footboard just at the bottom of the fender. They must just lift their heels up, pull their foot back, and stomp on the lock petal. They don't even know that they do it. I just mumble to myself and unlock the silly thing. /w3tcompact/icons/crazy.gif Women!! /w3tcompact/icons/wink.gif
Terry
/ Differential lock/4x4 #31
Chris, Terry's right. As you know, anytime you turn at all, all 4 wheels do not travel the same distance. The difference in the distance one rear wheel travels in relation to the other rear wheel is compensated for by the differential (unless you have the differential lock engaged which you should not do unless you intend to travel in a straight line only). The same is true of the front wheels; however, on our tractors and a lot of other 4WD vehicles, there is no third differential to take care of the difference in distance traveled by the front wheels in relation to the rear wheels. AWD (all wheel drive) cars and trucks do have that third differential. It's probably also nearly impossible to get an exact rolling circumference ratio between your front and rear wheels, so tractors with properly matched tires usually have a very slight "lead" on the front wheels; i.e., they are very slightly pulling ahead of the back end. So, in other words you're putting quite a bind on the drive line unless the tires can slip just a little bit, which they do quite well in dirt, grass, snow and ice, etc.
/ Differential lock/4x4 #32
Thanks, Bird and Terry. That makes perfect sense!
--Chris
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
2016 Audi A6 AWD Sedan (A64557)
2016 Audi A6 AWD...
2005 Infiniti FX35 AWD SUV (A66738)
2005 Infiniti FX35...
2022 CHEVROLET GM515 SIVERADO 4X2 S/A FLATBED TRUCK (A67737)
2022 CHEVROLET...
2014 CATERPILLAR 573C FELLER BUNCHER (A65053)
2014 CATERPILLAR...
