Different size rear tires on tractor
   / Different size rear tires on tractor #1
sigmrelics
Ellensburg, WA
John Deere 420
I have a JD 420 that had two 14.9-26 tires on it. One blew out and I replaced it with a 12-26. Both are recommended for this tractor, however, can having two different size tires on the tractor cause any damage to he tractor's drive train?
   / Different size rear tires on tractor #2
If tires are different diameters then the spider gears in the differential will be turning all the while the rear tires are turning which could shorten the spider gears & shafts which could cause premature failure of spider gears & shafts.
   / Different size rear tires on tractor #3
I have a 75hp tractor with a 16.9/26 on one side and a 18.4/26 on the other and been that way for 10 years doing 3-400 hrs a year . Will get around to changing it one day :)
   / Different size rear tires on tractor #4
If the outer diameter is the same, no problem at all.
   / Different size rear tires on tractor #5
In addition to extra wear and tear on differential gears, unequal traction from different footprint can cause instability in some circumstances.
   / Different size rear tires on tractor #6
I could see it wanting to turn in the direction of the side with the smaller diameter tire when the diff lock is used.
DESK (A53843)
DESK (A53843)
1261 (A50490)
1261 (A50490)
2017 E-Z Beever M12R Towable Brush Chipper (A50322)
2017 E-Z Beever...
2016 Genie GS-3369RT (A50123)
2016 Genie...
Heavy Duty Jumper Cables (A51694)
Heavy Duty Jumper...
2017 Bayliner VR5 21ft Bowrider Boat with 29ft T/A Boat Trailer (A51694)
2017 Bayliner VR5...
