Different size rear tires on tractor
   / Different size rear tires on tractor #1
sigmrelics
Ellensburg, WA
John Deere 420
I have a JD 420 that had two 14.9-26 tires on it. One blew out and I replaced it with a 12-26. Both are recommended for this tractor, however, can having two different size tires on the tractor cause any damage to he tractor's drive train?
   / Different size rear tires on tractor #2
If tires are different diameters then the spider gears in the differential will be turning all the while the rear tires are turning which could shorten the spider gears & shafts which could cause premature failure of spider gears & shafts.
   / Different size rear tires on tractor #3
I have a 75hp tractor with a 16.9/26 on one side and a 18.4/26 on the other and been that way for 10 years doing 3-400 hrs a year . Will get around to changing it one day :)
   / Different size rear tires on tractor #4
If the outer diameter is the same, no problem at all.
   / Different size rear tires on tractor #5
In addition to extra wear and tear on differential gears, unequal traction from different footprint can cause instability in some circumstances.
   / Different size rear tires on tractor #6
I could see it wanting to turn in the direction of the side with the smaller diameter tire when the diff lock is used.
2020 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2020 John Deere...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A53426)
2018 FREIGHTLINER...
(3) Stihl Chainsaws (A50123)
(3) Stihl...
2017 Ford Transit Connect Cargo Van (A51692)
2017 Ford Transit...
Gravely Compact Pro Zero Turn Mower (A53117)
Gravely Compact...
2017 TOP HAT TRAILER 16 FOOT UTILITY TRAILER (A53843)
2017 TOP HAT...
