Different size rear tires on tractor
   / Different size rear tires on tractor #1
sigmrelics
Ellensburg, WA
John Deere 420
I have a JD 420 that had two 14.9-26 tires on it. One blew out and I replaced it with a 12-26. Both are recommended for this tractor, however, can having two different size tires on the tractor cause any damage to he tractor's drive train?
   / Different size rear tires on tractor #2
If tires are different diameters then the spider gears in the differential will be turning all the while the rear tires are turning which could shorten the spider gears & shafts which could cause premature failure of spider gears & shafts.
   / Different size rear tires on tractor #3
I have a 75hp tractor with a 16.9/26 on one side and a 18.4/26 on the other and been that way for 10 years doing 3-400 hrs a year . Will get around to changing it one day :)
   / Different size rear tires on tractor #4
If the outer diameter is the same, no problem at all.
   / Different size rear tires on tractor #5
In addition to extra wear and tear on differential gears, unequal traction from different footprint can cause instability in some circumstances.
   / Different size rear tires on tractor #6
I could see it wanting to turn in the direction of the side with the smaller diameter tire when the diff lock is used.
2004 Ford E-350 Passenger Van (A51692)
2004 Ford E-350...
25077 (A51694)
25077 (A51694)
2014 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2014 DRAGON...
2012 Ford F250 XLT, Super Cab Long Bed (A52384)
2012 Ford F250...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Altec AT41M Boom (A53473)
2016 RAM 5500...
