different fluid effect on hydraulic motor
/ different fluid effect on hydraulic motor #21
I am thinking the only true answer will be with a flow and pressure test, and if it checks out correct, then a good 24 cu in hyd motor, and 3400 psi should generate about 12,994 in lbs or 1,082 ft lbs, and that should dig a hole in just about any ground.
Put the hyd gage in the auger motor IN hose in a tee and you will see the pressure developed by the hyd motor.
In neutral, the motor spool work ports are tied to tank, and I can see that if the aux valve OUT port is tied into a common return line, that return/tank flow from other hyd flow could make fluid come out the motor spool using back pressure.
In order to get the max flow through the hyd motor, you could bypass the QD on the return path and run a hose directly to tank.
Can you make a video of both skid steers using the same auger, showing the pressure gage.
Are you using an aggressive starter bit like these?
I hooked the auger to the new skid steer today. This skid steer flows 24 GPM and the original one 19 GPM. With the higher flow as suspected the auger spins faster but still has the same torque due to the fact the pressure is the same. I made a video of it drilling. Auger drillng - YouTube
The ground here is pretty easy and it goes good for about 5' then starts getting tough. The soil I am digging through doesn't really change at that depth it is just the resistance of the auger flighting in the hole I think. In other places where I am drilling it will sometimes stop the rotation at 2-3 feet and I have to baby it the whole way going up and down.
On this skid steer the pressure goes to 3000 PSI under heavy load and the return pressure stays around 200 PSI. I still have not found a good way to go to tank. The hydraulic reservoir on the skid steer is plastic and is buried in the engine compartment. It does not have any unused ports to connect to. There is a big line leaving the bottom of it (suction I assume) and a 1" or so line coming in the top. I guess I could tee into this line? The hydraulics on the skid steer look so complicated with lies running everywhere I hate to jack with it and screw something up.
My bit looks a lot like the center bit in your photo. My auger is not big enough to have the outer teeth like that one though.
/ different fluid effect on hydraulic motor #24
That ground looks hard, but if not, I believe you are adding more resistance to the load by leaving the dirt in the hole.
I would suggest driving the bit in the ground at full speed and when it slows, then pull the auger out fast still spinning, and repeat the process until you are at the depth you want.
Drilling in wood and cement for example, you have to keep the hole clean.
This video is similar to how I dig holes.
Fast Bobcat Auger - YouTube
http://youtu.be/8llPg8xeuos
Keep the speed and pressure high.
Here is the HP the pump is using to produce the 24 GPM's in order to turn the motor at
PUMP DISPLACEMENT HORSEPOWER TO DRIVE PUMP
Desired Flow 24 GPM Desired Flow 24 GPM
Operating Speed RPM System Pressure 3400 PSI
Displacement Required cubic inches Horsepower 56 HP
calculated for electric motors
double HP for gas powered motors
Motor speed should be around 241, if flowing 24 GPM's in to it, and developing about 12,994 in lbs of torque.
I observed the motor running very slow.
So by running the hyd motor slow, you are not using the GPM's necessary to put that available HP/torque into the ground.
Were you running the engine full rpm, and giving the motor all the flow available?
Those are my thoughts anyway.
/ different fluid effect on hydraulic motor #25
If the cutting bit is the same or smaller then the auger it well not bore at all. Might want to double check that.
The engine is at full throttle and I am running the auger as fast as it will go. It is slowing down due to the load. Once it starts doing that even if I just barely put down pressure it goes slow or stops.
This essentially is the core of my problem. When the digging gets tough the rotation slows to a crawl and even stops. I have to feather the auger up and down to do any drilling and while I am able to dig the holes it takes a long time. If I was just digging a few here and there it would be no problem but I want to be able to dig 100 or so per day. In my video for example I dig the first 6' in about 20 seconds which is great but the last 4' takes a minute and a half. While this is not all that bad in other ground conditions it might take me 5-10 minutes to dig one hole constantly going up and down. Not only does this take time but it seems to be hard on the machine as it gets hot.
I am wondering what my solution might be? I am guessing a bigger displacement motor would have more torque and would do better I am just wanting to make sure there is nothing wrong with my setup before I go to buying a new $1000 motor.
They are the correct size as recommended by the manufacturer. 3.25" diameter auger and 3.5" diameter bit. I have wondered if a bigger bit would help but they say no because it won't be able to lift the cuttings out if the hole is too much bigger than the auger.
/ different fluid effect on hydraulic motor #28
If you have it on the 3pt that case well pull it out.
I am not talking about the auger. I can lift it out of the hole no problem. I am talking about the cuttings, the dirt.
If the bit is too big for the auger the hole becomes too big and the dirt is not carried up and out of the hole by the auger as it just falls back down the sides of the hole.
/ different fluid effect on hydraulic motor #30
When I dig holes I don't spin the auger fast and when deep enough I pull the auger without it spinning. Realy gets big if spinning fast while pulling out. When the auger bottom gets to the top it goes all over the place. I just keep going back in the hole spin long enough for auger to fill up, stop then pull. It's not easy my yourself, need someone to the push the auger away from the hole and get the dirt off. On mine I can push it real hard to the tractor and it hits a stop and dirt well fly off if dry.
Don't get in a hurry with a post hole digger, a man can get hurt real bad.
/ different fluid effect on hydraulic motor #31
bdog,
Since I have never operated a skid steer mounted PHD I have what may be dumb question but.. I am going to ask anyway.
Does the auger have any freeplay in tilt or tip function? I.e. As you are drilling the hole is the auger allowed to follow the hole or does the loader geometry force the auger against the side of the hole potentially causing binding? From the reading through your posts showing pressure readings, the motor is trying to generate torque, something is physically / mechanically preventing it from turning.
/ different fluid effect on hydraulic motor #32
Can you show us a good close up picture of the cutting bit.
/ different fluid effect on hydraulic motor #33
The ground just naturally gets harder at that depth because it's compacted. In your video it looks like you're maybe pushing down too hard when it's in deep. Can you just feather the down valve when it starts turning hard? Just a thought.
bdog,
Normally with a PHD either on 3 point or a skid steer mount it wobbles around but it isnt normally an issue as you usually are only drilling 3 foot or so deep.
On my drill the auger is contained in a mast and is driven up and down by a separate hydraulic cylinder. It cant really move around much and drills pretty straight. I am sure some of the binding is due to the hole not being perfectly straight though.
I can feather it but it doesn't make it go any faster. In the video I am just trying to drill it as fast as I can. I have found that when it gets to where it doesn't want to turn the fastest way to make progress is to jab the bit up and down. The hydraulics are really touchy also it lifts up in a hurry if it is not spinning.
/ different fluid effect on hydraulic motor #37
I am still betting that the ground material left in the hole is causing much resistance.
I would pull the auger out turning every couple of feet dug to get rid of the material.
One other thing is if the fluid gets real hot, the hyd motor will bypass some of the fluid and lose some efficiency.
Is the hyd motor getting all the fluid or is the fluid shared by the lift and descend valve/cyl.
Otherwise, does the hyd motor slow when the lift is moving downward?
2020 CATERPILLAR 303.5E2 EXCAVATOR (A60429)
2020 CATERPILLAR...
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55852)
2023 Fat Truck...
12 X 20 CAR PORT (A58214)
12 X 20 CAR PORT...
Hydraulic Log Splitter (A59228)
Hydraulic Log...
2023 John Deere 333G Compact Track Loader Skid Steer (A59228)
2023 John Deere...
RING 2 STARTS HERE @ 9:15 AM (A60432)
RING 2 STARTS HERE...
