Different BH-75 Hoe Problem on B3030HST
/ Different BH-75 Hoe Problem on B3030HST #1
3030PJ
Western WA
Kubot B3030HST
Hi All,
My first post on this forum after a few months of lurking. Anyhooo..I finally stepped up and bought a B3030/FEL/BH-75 a couple of weeks ago. After about 3 months of comparing I thought it was the best fit for my needs, both physically and financially. All is well except when I have the BH-75 Hoe disconnected from the tractor. When the now stand alone hoe is sitting level in my shop, the top "O"-rings on the "crowd/bucket" control stick leak hyraulic fluid out the top. It only happens when the hoe is NOT plumbed into the tractor! I've had the hoe off about 3 times now and the leak doesn't seem quite as prevalent as it was. Any ideas before I succumb to the hassle of getting the unit back to the dealer? I always "unload" the hydraulic pressure prior to disconnecting the hyd. hoses if that means anything. No other problems (yet) with the tractor/FEL or hoe. No vibrations on the B3030 that others have mentioned. <font color="red"> </font> <font color="black"> </font>
/ Different BH-75 Hoe Problem on B3030HST #2
I have the same setup and no leak... but I have vibration. IMHO it's not normal and it should be checked by your dealer.
OK, I just used the hoe for 2 hours today and now all the control stick "o"-rings are leaking hydraulic fluid out the top, including the out rigger levers...while the machine's running. Guess I got to get it to the dealer. How big a deal is it to swap out the control valve/stick "o"-rings?
/ Different BH-75 Hoe Problem on B3030HST #4
Definitively you'll need the assistance of your dealer on this one. /forums/images/graemlins/frown.gif
/ Different BH-75 Hoe Problem on B3030HST #5
The only thing that I could think that would cause what you are describing is excess pressure. I mean really, really high pressure.
Gravely Field Cultivator Attachment (A65640)
Gravely Field...
2004 Caterpillar 315CL Excavator (A64194)
2004 Caterpillar...
Connect CH65 Hydraulic Breaker Excavator Attachment (A64194)
Connect CH65...
2007 CHEVY C4500 WESTERN HAULER (A65643)
2007 CHEVY C4500...
John Deere 4840 Tractor (A66285)
John Deere 4840...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
