Difference between LET862C & LET802C Engines? (I have SD1840 tractor)
   / Difference between LET862C & LET802C Engines? (I have SD1840 tractor) #1
Temblor
Wa
Kubota B7100 Shibaura SD1840 (Ford 1500)
I have a SD1840 tractor with a LET802C engine. I was given a FORD 1500 Service Manual with it and told it was the same tractor? But the Ford 1500 shows a LET862C engine and I am wondering if there are differences major or minor in these two engines?
Fuel Injection system? Timing?
Thanks in advance for any help.
   / Difference between LET862C & LET802C Engines? (I have SD1840 tractor) #2
It isn't the same tractor. It is the closest model that has an English repair manual. Hard to tell how close they are without comparing part #s. There are the same series of engine with a different bore, so they should be fairly similar.
   / Difference between LET862C & LET802C Engines? (I have SD1840 tractor) #3
These are different engines: the LET802C has 804 cc displacement and an 80.0 mm cylinder bore, while the LET862C has 1,134 cc and 86.0 mm, respectively
2016 Freightliner M2 106 Braun Ambulance (A53422)
2016 Freightliner...
18" PIN ON BUCKET (A52707)
18" PIN ON BUCKET...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A55302)
2018 John Deere...
2008 Ford Fusion SE Sedan (A54815)
2008 Ford Fusion...
Informational Lot - Shipping (A55302)
Informational Lot...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
