Difference between LET862C & LET802C Engines? (I have SD1840 tractor)
   / Difference between LET862C & LET802C Engines? (I have SD1840 tractor) #1
Temblor
Wa
Kubota B7100 Shibaura SD1840 (Ford 1500)
I have a SD1840 tractor with a LET802C engine. I was given a FORD 1500 Service Manual with it and told it was the same tractor? But the Ford 1500 shows a LET862C engine and I am wondering if there are differences major or minor in these two engines?
Fuel Injection system? Timing?
Thanks in advance for any help.
   / Difference between LET862C & LET802C Engines? (I have SD1840 tractor) #2
It isn't the same tractor. It is the closest model that has an English repair manual. Hard to tell how close they are without comparing part #s. There are the same series of engine with a different bore, so they should be fairly similar.
   / Difference between LET862C & LET802C Engines? (I have SD1840 tractor) #3
These are different engines: the LET802C has 804 cc displacement and an 80.0 mm cylinder bore, while the LET862C has 1,134 cc and 86.0 mm, respectively
2014 Ford Expedition SUV (A55853)
2014 Ford...
2016 Ford Explorer AWD SUV (A53424)
2016 Ford Explorer...
2015 MACK CHU (PINNACLE) TRI AXLE(INOPERABLE) (A55745)
2015 MACK CHU...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
2018 JLG G5-18A (A50123)
2018 JLG G5-18A...
