Difference between JD 5055D and JD 5055E?
/ Difference between JD 5055D and JD 5055E? #1
xccoach
JD 5055d
Now I know the 5055E is a four wheel drive tractor and the 5055D is two wheel drive, but the list price difference is $6100 ($17000 vs $23100). Is there anything else different (read better) :confused:between the two tractors ... seems like a lot of money for the extra hardware used in four wheel drive, or is Deere just taking advantage of the incremental market demand for four wheel drive tractors?
/ Difference between JD 5055D and JD 5055E? #2
If I'm not mistaken the 2wd has a 8x4 tranny, the 4wd has 9x3 snycronized. Both are real capable machines!
/ Difference between JD 5055D and JD 5055E? #3
The rear lift capacity differs between the two models also. A suggestion: Go to the website TractorData.com -you will be able to compare more. Hope this helps.
/ Difference between JD 5055D and JD 5055E? #4
I'm looking at the 5055e right now. According to the glossy brochure the "e" has 18.2 gpm hydraulic flow compared to 17.4 for the "d". The "e" has a slightly larger fuel tank, partially synchronized shifting between gears within a range, better rear lift capacity, longer wheelbase and finally, more weight.
Is all that worth the price difference? For me it is since I want MFWD. Otherwise I'm not sure.
/ Difference between JD 5055D and JD 5055E? #5
The D also has a tighter turning radius.
Thanks Rick, I am leaning the same way, what tractor are you moving out of?
/ Difference between JD 5055D and JD 5055E? #7
I have been without a tractor (insert sad face here) for the last three years, but I owned a very small John Deere 4010 for a couple of years when we only had 4 acres. It had all of 21 hp and would get the job done if I had time and patience. We have since purchased 33 acres that I plan on farming, thus the need for a much bigger tractor.
How about you?
I am trading in a Kubota zero turn mower, the versatility of a tractor is reason. I did end up getting the 5055D as I don't think I need the MFWD for my uses and property, thanks for your help.
/ Difference between JD 5055D and JD 5055E? #9
Excellent! Now, please post pictures. New paint is always pretty!
Will do.
FLEX HEADER REEL FOR 20' HEAD (A63291)
FLEX HEADER REEL...
2020 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2020 Ford F-150...
2018 Ram 1500 Reefer Meal Delivery Truck (A61573)
2018 Ram 1500...
Roll of 2-inch Vacuum Hose (A57454)
Roll of 2-inch...
2018 John Deere 333G Track Loader (A63111)
2018 John Deere...
2020 Freightliner 114SD T/A VacCon VPD3611 Combination Sewer Jetter Vacuum Truck (A61573)
2020 Freightliner...
