sandman2234
Super Member
- Joined
- Dec 4, 2005
- Messages
- 6,075
- Location
- Jacksonville, Florida
- Tractor
- JD2555 and a few Allis Chalmers and now one Kubota
Well, for the last year, I have been considering buying a heavier duty p/u so I could move my tractors without having to drive them to their destinations. A used Ford F350 has been chosen, and maybe one day I will actually take pocession of it, but that is another story.(2000 model with 7.3 and standard transmission) I have a few questions about diesel p/u's that hopefully can be answered easily.
What am I looking at as far as maintance compared to a gas engine. Is there anything that has to be done that a gas driving person wouldn't think about, or things that are done more often, or not at all?
With a gas vehicle, you give the throttle a little nudge, and ease out the clutch. With a tractor trailer, you will burn the clutch out doing that, as you let the clutch out and then give it throttle to prevent "slipping the clutch". Which was do diesel p/u's do it? I will probably figure that one out the first time I actually drive the chosen truck, but for now I thought I would ask.
I am not going to ask about fuel mileage, but wondered if there are any tricks to installing a fuel extender (larger tank). I probably won't need it, as the truck won't drive far to get me to work and back and when toting a load, it will only go about 300 miles, but i was curious since I am only about 30 miles from a cheaper place to buy fuel, but buying it for a single tank doesn't make that much of a savings. I could probably buy all my fuel up there if I add about 100 gallons of capacity. May or not make any financial sense, jury is still out on that one.
Fifth wheel hitches...
Truck has one, and when I go to pick it up, I will also pick up a well used trailer. Makes sense for what he wants for the trailer just to load my p/u on it and drive back home.(900 miles) Recently replaced axles and tires on the trailer, so that shouldn't be a problem. I can handle a tractor trailer, so I don't think this smaller version is going to be a problem, but there are always little tricks to everything. The truck is getting very limited miles since Feb, so is there anything I need to do before starting out on the road with it?Any suggestions? David from jax
