diesel oil
   / diesel oil #5
I have never heard of type N motor oil and I can not google up any hits for it. What are you calling type N oil?
   / diesel oil #6
Welcome to TractorByNet!
We moved your thread to the Oil, Fuel, & Lubricants forum. :)
   / diesel oil #7
By "n" do you mean API SN classification? Some tractors, such as Kubota's until around 2011 or so, only require the older API CF classification. Many newer brands/weights of passenger car motor oils(PCMO) marked API Sx(x=L,M or N) will qualify for the older diesel classification CF. Even though the PCMO qualify they are not usually marked with the older CF designation. So technically you could use them in place of a CF oil. I would not use a API SN oil in place of the CF qualified HDEO though, unless it was just for topping off or an emergency. Too many good HDEO are available at reasonable prices and available pretty much everywhere. So if I understood your question correctly: You can but it would not be ideal. I would shorten the oil change interval if doing so.
2016 Freightliner 114SD T/A 4,000 Gallon Water Truck (A53422)
2016 Freightliner...
2004 Ford F-250 4x4 Service Truck with Liftgate (A53422)
2004 Ford F-250...
2019 CATERPILLAR D6T LGP HI-TRACK CRAWLER DOZER (A52705)
2019 CATERPILLAR...
UNUSED LANDHONOR SGB-11-72W 72" GRAPPLE BUCKET (A54757)
UNUSED LANDHONOR...
UNUSED RAYTREE RMRB72 - 72" POWER RAKE BUCKET (A54757)
UNUSED RAYTREE...
2021 Kubota RTV X900 4x4 Utility Cart (A53421)
2021 Kubota RTV...
