diesel oil
   / diesel oil #5
I have never heard of type N motor oil and I can not google up any hits for it. What are you calling type N oil?
   / diesel oil #6
Welcome to TractorByNet!
We moved your thread to the Oil, Fuel, & Lubricants forum. :)
   / diesel oil #7
By "n" do you mean API SN classification? Some tractors, such as Kubota's until around 2011 or so, only require the older API CF classification. Many newer brands/weights of passenger car motor oils(PCMO) marked API Sx(x=L,M or N) will qualify for the older diesel classification CF. Even though the PCMO qualify they are not usually marked with the older CF designation. So technically you could use them in place of a CF oil. I would not use a API SN oil in place of the CF qualified HDEO though, unless it was just for topping off or an emergency. Too many good HDEO are available at reasonable prices and available pretty much everywhere. So if I understood your question correctly: You can but it would not be ideal. I would shorten the oil change interval if doing so.
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2016 FREIGHTLINER...
2017 FOREST RIVER 20 T/A CARGO TRAILER (A53843)
2017 FOREST RIVER...
2013 MACK GRANITE (A52472)
2013 MACK GRANITE...
22ft T/A Gooseneck Flatbed Equipment Trailer (A52377)
22ft T/A Gooseneck...
2023 Caterpillar 299D3 High Flow XPS Compact Track Loader Skid Steer with CAT GB124 Grader Blade (A52377)
2023 Caterpillar...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A54811)
Generac Yanmar...
