Oil & Fuel Diesel mixing with motor oil
   / Diesel mixing with motor oil #11
Just a stupid question but are any of your fluids (ie coolant hydro fluid etc) low? -Ed
   / Diesel mixing with motor oil #12
But is it not common for diesel oil to look runny very soon after fresh?
   / Diesel mixing with motor oil #13
If you're talking diesel engine oil - like 15W40 - the answer is no. Relative to viscosity, it's no different than any other engine oil. The main difference is how it suspends contaminates small enough to pass through the filter. That's why diesel engine darkens during use.
If you're talking about diesel fuel at normal temperatures - again, no. If untreated however, it will gel (thicken) in extreme cold.
//greg//
   / Diesel mixing with motor oil #14
I agree with Greg .
Soundguy
   / Diesel mixing with motor oil #15
Sorry - too late to edit my mistake. It should have read: "That's why diesel engine oil darkens during use ".
//greg//
   / Diesel mixing with motor oil #16
I was remiss in responding to the final conclusion to my problem. In the end two of the injectors were not working properly and I found that I had two bent push rods on the number on cylinder. A compression check showed that all of the cylinders were pushing 315+ pounds and fixed.
Again thanks for everones help
Craig
2019 Harley Davidson 114 Police (A50324)
2019 Harley...
2021 CATERPILLAR 299D3 XE SKID STEER (A51242)
2021 CATERPILLAR...
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
Flatbed Body for Heavy Truck (A50854)
Flatbed Body for...
Yanmar YFL-1575 33HP Utility Loader Tractor (A49461)
Yanmar YFL-1575...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
