Oil & Fuel Diesel mixing with motor oil
   / Diesel mixing with motor oil #11
Just a stupid question but are any of your fluids (ie coolant hydro fluid etc) low? -Ed
   / Diesel mixing with motor oil #12
But is it not common for diesel oil to look runny very soon after fresh?
   / Diesel mixing with motor oil #13
If you're talking diesel engine oil - like 15W40 - the answer is no. Relative to viscosity, it's no different than any other engine oil. The main difference is how it suspends contaminates small enough to pass through the filter. That's why diesel engine darkens during use.
If you're talking about diesel fuel at normal temperatures - again, no. If untreated however, it will gel (thicken) in extreme cold.
//greg//
   / Diesel mixing with motor oil #14
I agree with Greg .
Soundguy
   / Diesel mixing with motor oil #15
Sorry - too late to edit my mistake. It should have read: "That's why diesel engine oil darkens during use ".
//greg//
   / Diesel mixing with motor oil #16
I was remiss in responding to the final conclusion to my problem. In the end two of the injectors were not working properly and I found that I had two bent push rods on the number on cylinder. A compression check showed that all of the cylinders were pushing 315+ pounds and fixed.
Again thanks for everones help
Craig
CUSTOM ALUMINUM 16FT CAR TRAILER (A51222)
CUSTOM ALUMINUM...
2008 MACK GRANITE HOT OIL (A50854)
2008 MACK GRANITE...
LOOK! (A50657)
LOOK! (A50657)
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
2007 CHEVROLET SILVERADO 4X4  DUALLY TRUCK (A51222)
2007 CHEVROLET...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
