Diesel fuel noob . . .
   / Diesel fuel noob . . . #21
If locals bought the diesel the same place many of them truckers bought it they would have had gelled fuel in their tractors.
BUT, only if they drove their tractors to another state like those truckers did.
SR
   / Diesel fuel noob . . . #22
SR
We started seeing semi’s on the side of the highway right away the morning we left Tulsa, it was 19° in Tulsa Oklahoma, something I’m guessing the fuel suppliers weren’t planning on.
The first three or four we wondered what was going on, but then when we started seeing some of them with heaters under the fuel tanks with a shelter of cardboard or something around it, I just figured it was bad fuel that was gelling
   / Diesel fuel noob . . . #23
Its added if the fuel is going to sit for a longer period, like if you rarely use the machine or have a large storage tank, otherwise it's not really needed.
Using a Winter Anti-Gel additive during winter in cold climates is a good idea, however.
I never used an antigel in the 40 years I have been running diesels here in N. Tx. until last, or the year before last, winter when the temp got down to single digit F temps it told me that I should have installed the anti-gel additive......I had no idea it was going to get that cold....never has since 1978. Since then it has been part of my fillips regardless time of year as I don't know if that fueling will still be in the tanks in the upcoming winter.
I buy from one source and it feeds the local farm industry so I don't expect any purchasing problems. I have a 20' delivery hose and between the tank and hose is a Golden rod (or something like that name) final filter. I have 3ea. 55 gallon tanks in a trailer made from a PU bed. I keep the tanks under cover and plugged so that they don't breathe with weather changes. I use Power Services additives per the container recommended ratios. I have 7 diesels and have had for awhile and usually had a couple or so sitting around.
Other than purchasing a used tractor with an injector problem, I have never had a problem with my diesels and can't say that for the gassers I had before I converted to diesels.....bullet proof if you keep the fuel clean. I have a Ford 3910 that was vibrating at max RPM but bleeding the injectors a couple of times pretty well solved that problem.
   / Diesel fuel noob . . . #24
Diesel doesn't gel at 19 degrees. The problem was more likely ice. Apparently when they lowered the sulfur content, it created a higher likelihood of ice as the water separates and freezes.
Also, 19 is not an unusual low temp in Tulsa. It's below average, but in an average year they get a little over a week where temps drop below 20. We're hours south of Tulsa and we still get a handful of sub-20s lows.
   / Diesel fuel noob . . . #25
Hi all: I bought a '13 New Holland T1510 last month, got rid of my '51 Fergie that needed A LOT of work.
I have never owned anything diesel before. I saw someone mention online that you need to add an anti-algae substance to the fuel. A trusted local buddy said you don't need to, it's a standard additive in all the pump fuel -- around here anyway (northeast).
Googling/AI I get mixed results. :(
What say you?
I’m in east Texas and I use anti-gel treatment in my truck and tractor. I have had my truck, 2012 Ram, refuse to start because the fuel gel’s up. I had to take the fuel tank off of my tractor one year because it had algae/gel clumps big enough to block the fuel outlet so bad. I don’t know what the difference is in the “winter blend” but in east Texas I cant see anything different.
   / Diesel fuel noob . . . #26
I think that article is a little misleading. Yes it does state that ice is a problem before gelling and gelling typically happens Around 10F. But filters plug and shut off the fuel supply when the cloud point is reached. For untreated #2, that’s typically 14F to 20F.
   / Diesel fuel noob . . . #27
Actually, my original question was about anti-algae additives. My tractor isn't going anywhere except to plow my driveway in the winter.
But that's fine, this other stuff is interesting too. :)
I would think you can get #1 diesel in that part of the country during the cold months (Sep - Apr ?)
   / Diesel fuel noob . . . #28
In my opinion, adding an additive is fairly cheap insurance. I use a multi purpose additive as my old tractor was designed around higher sulfur fuel. The sulfur added some lube to the fuel. Since I add the additive anyway, and my tractor may sit for periods of time, why not be sure that the additive which will go in for extra lube also is anti-algae and anti-gel?
   / Diesel fuel noob . . . #29
I buy diesel at the gas station, but got spooged twice. Now I always add some biocide.
   / Diesel fuel noob . . . #30
All I know is that I filled up eight 5gal tanks with diesel from a busy station when I wanted to start storing a little extra fuel around the property. It sat for a year and when I went to cycle it thru there were huge globs of black goo that had formed. Having little knowledge of diesel, I was not sure what it was. I tried to filter it out with a screen and the gunk clogged up the screen something horrible. I found it was algae. I now use biocide and anti-gel 100% of the time. Have not had an issue since. For the quantities I store (40-60 gal) it is very cheap insurance. If I was storing 200 gallons the economics change and I might consider alternatives.
golf cart electric (A55787)
golf cart electric...
2016 KUBOTA K008-3 MINI EXCAVATOR (A52709)
2016 KUBOTA K008-3...
2019 PJ  40FT GOOSENECK TRAILER (A58214)
2019 PJ 40FT...
2024 LS MT242E MFWD Compact Utility Tractor with LL3003 Front Loader (A55302)
2024 LS MT242E...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
Komatsu FD40T-7 Forklift (A54865)
Komatsu FD40T-7...
