Diesel Engine Oil
/ Diesel Engine Oil #81
I plan to use the Castrol Edge in my 1025 because it's the only xw30 oil that I can get that's diesel rated. Every other diesel rated oils available around here (and even in Ohio where I checked some) are xxw40 oils. My temperature chart shows I don't need a 30w, and I want to save fuel by using xw30. Going to 0w20 in my Tacoma has really improved the fuel mileage on it.
Amsoil (I don't sell the stuff) has a CJ-4 10W30, and a pre-emission 10w30 and 5w30. I don't remember the spec you need for that engine.
AMSOIL Synthetic Diesel Motor Oil, Engine Oil
Rgds, D.
/ Diesel Engine Oil #82
use Mobil1 Turbo Diesel Truck in all our diesel vehicles...good oil. Use Rotella T6 in the Yamaha Rhino
/ Diesel Engine Oil #83
I've used Delvac1 (more or less TDT) - I've liked it and all the Mobil products I've used in the past. If my cash flow was stronger at the moment, I'd probably buy more than I do - up Nord here, real sales on Mobil seem rare, at least in the stores I frequent.
Rgds, D.
/ Diesel Engine Oil #84
Getting ready for 50 hour initial oil change (flush the break-in machining), couldn't find 10W-30 CG+ mineral oil so did what everybody else does - went with 15W-40 until winter, then change to synthetic. Ended up with Mobil Delvac 1300 Super 15W-40.......overkill for a mechanically-injected, nonturbocharged, IDI diesel engine, but what the hey. And only needed 3 quarts, not a 5 gallon pail.
Winter changeover will be Mobil Delvac 1 5W-40 or Mobil 1 Turbo Diesel 5W-40, for low temperature pumpability.
/ Diesel Engine Oil #85
Rgds, D.
Where are you buying Delvac??
/ Diesel Engine Oil #86
I was after Delvac1 at the time......
An Industrial Distributor in Etobicoke. Been a while, so I can't remember the name..... I think I tracked them down through the Mobil site back then. Went looking now... pretty sure it was Noco. Bought a case of 4L jugs (x4) - can't remember if that was the minimum purchase, or I just wanted that much.
NOCO LUBRICANTS COMPANY
2 BRADPENN RD
ETOBICOKE
ON M8Z 5S9
1-800-414-6626
Gold Circle of Excellence Award 2011-2012
NOCO Fuels and NOCO Lubricants
Rgds, D.
/ Diesel Engine Oil #87
I was going to say that this is a Canadian thing.... but this search tool seems to work for USA too:
Find an Imperial Oil Distributor | Mobil
If you are seeking a specialty Mobil lube not common at your local retailer, one of the Disti's may help.
Rgds, D.
/ Diesel Engine Oil #88
2 BRADPENN RD
ETOBICOKE
ON M8Z 5S9
1-800-414-6626
Rgds, D.
Thanks on both Counts!!
/ Diesel Engine Oil #90
Good plan - 5W40 is nice for winter, and minimizes aux heating requirements.
Rgds, D.
2011 Chevrolet Impala Sedan (A59231)
2011 Chevrolet...
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A59823)
2017 KALMAR OTTAWA...
TANK MANIFOLD (A55745)
19008 (A56859)
19008 (A56859)
2023 JOHN DEERE XUV 590M S4 UTV (A59823)
2023 JOHN DEERE...
UNUSED 2026 INDUSTRIAS AMERICA HYD TILT TRAILER (A60430)
UNUSED 2026...
