I had already dumped anti-gel into the tank, but I think the gel in the filter happened before I could get the anti-gel in it. At any rate, I drained half the tank and saw no signs of gelling.
Here's the no-fail procedure I found today for de-gelling a fuel filter...
1) put the filter in a plastic bag and stick it in your pocket.
2) go to the local farm store and show them the filter and the gel on the filter.
3) have a lengthy discussion about de-gelling techniques and agree that none of them will really work. Spend more time looking up and cross referencing numbers in the remote hope that they may have a fuel filter on the shelf. (they don't)
4) buy winter blend diesel.
5) come home and drain half your fuel tank. Refill with winter blend diesel.
6) pull the filter out of your pocket and realize that your body heat had warmed the filter to the point that there are no signs of gel on it.
7) put it in the tractor and fire her up.
The tractor is running right now! I'm going to go plow slush now. (it used to be snow, but it's melting now. I have to get it plowed before it freezes into a solid block of ice.)
