Diesel engine gradually slows and dies
/ Diesel engine gradually slows and dies #1
Iplayfarmer
Super Member
Idaho
Massey Ferguson 1215, Case 801B
Here's hoping this is one of those easy fixes that I should already know. The engine on my little Massey 1215 will start right up, but then it gradually loses power over about 30 seconds and dies. I'm guessing that it's a fuel filter. The dealer is closed until Monday. If I haven't figured something else out by Monday I'll call and order a fuel filter and hope it works.
/ Diesel engine gradually slows and dies #2
Any smoke or other symptoms? Fuel filter sounds very possible
/ Diesel engine gradually slows and dies #3
If you have nothing else to do until Monday you might want to take the filter out and blow it off and clean the bowl...maybe some water or junk and put the fuel filter back in and you could still use it until you get a new filter..It is a pretty quick thing to do...:)
/ Diesel engine gradually slows and dies #4
I presume it's a diesel engine. What's the ambient temperatures that you're operating in? If it's cold, I'd suspect retricted fuel flow from some water in the filter or water separator is limiting fuel flow. I had a case of that last week with temps in the teens. I put a heat gun on the filters and then drained them and reprimed and started and it has run fine since. I'll replace the filters ASAP.
Okay, I got bored and pulled the filter. The filter had gooey slime all over it. Today it's 36 degrees, but last week we were sub zero. I'm guessing that this slime is gelled diesel. Any ideas on how to get the slime off. I wiped it off with a rag, but the slime is still stuck in the folds. I tried carb spray, but that didn't do much.
/ Diesel engine gradually slows and dies #6
If it has jelled you will need to put the tractor in a heated shed ... when its all thawed out add an anti jell to prevent future problems...
/ Diesel engine gradually slows and dies #8
yep.. could be biologicals or gelling.. or both.
I think I'd dump some biocide and fuel conditioner with anti gel into the tank, replace the filter, and then bleed her till she ran good at the pump.
use a hair dryer to get stuff going if needed.
soundguy
/ Diesel engine gradually slows and dies #9
A gooey slime may indicate bacterial growth. :)
I've never experienced that ... although I here its pretty common. I have to look and see if the fuel treatment I use as any biocide (sp) in it.
I had already dumped anti-gel into the tank, but I think the gel in the filter happened before I could get the anti-gel in it. At any rate, I drained half the tank and saw no signs of gelling.
Here's the no-fail procedure I found today for de-gelling a fuel filter...
1) put the filter in a plastic bag and stick it in your pocket.
2) go to the local farm store and show them the filter and the gel on the filter.
3) have a lengthy discussion about de-gelling techniques and agree that none of them will really work. Spend more time looking up and cross referencing numbers in the remote hope that they may have a fuel filter on the shelf. (they don't)
4) buy winter blend diesel.
5) come home and drain half your fuel tank. Refill with winter blend diesel.
6) pull the filter out of your pocket and realize that your body heat had warmed the filter to the point that there are no signs of gel on it.
7) put it in the tractor and fire her up.
The tractor is running right now! I'm going to go plow slush now. (it used to be snow, but it's melting now. I have to get it plowed before it freezes into a solid block of ice.)
/ Diesel engine gradually slows and dies #11
You are having FUN!!
/ Diesel engine gradually slows and dies #12
Now thats the way to get things done. Great. I read something on this forum every day that makes me smile.
Eddie
/ Diesel engine gradually slows and dies #13
I also got a smile out of it ... was anticipating #6 to include "Hole in the Plastic Bag ... Diesel Fuel in the Pocket"
Oh, Man!! I didn't even think of that. I'm glad it didn't happen.
/ Diesel engine gradually slows and dies #15
There are 2 types of slime that clog filters. The kind you saw from fuel below the cloud point (gel is actually FAR colder and the whole tank turns to the same consistency as the liquid in the turkey pan after sitting in the fridge overnight). The other kind is black. That is bio and it is NASTY hard to get rid of. But easy to prevent as the critters live in the diesel / water interface -- do be sure you have no free water in the fuel.
Good you got it back running and extra good the plastic didn't leak.
What's that smell, you ask?
Why, that's yer "Eau De Cologne" for Manly Men!:D
Funny you say that. When I come in smelling like gasoline, carb cleaner, or diesel my daughter will take a deep breath and exclaim, "I love that smell!" I'm sure it's not the smell that she likes so much as all of the memories associated with it. She spends a lot of time beside me when I'm tinkering.
/ Diesel engine gradually slows and dies #18
fuel running down your arm when you are laying out in the field under yer tractor also helps to keep the ants off of ya!
soundguy
soundguy
I also noticed that diesel fuel feels warmer than water in near freezing temperatures. I think it's due to the slower evaporation rate of the diesel.
/ Diesel engine gradually slows and dies #20
Yes, smells and memories are very intimately related. The smell of real hemp rope takes me back to before I was school age and out in our barn on a swing dad made for us. It's one of my earliest and most poignant memories.
(INOP) 2012 CHEVROLET TAHOE (A59823)
(INOP) 2012...
24in pin on tooth excavator bucket (A61307)
24in pin on tooth...
2015 REITNOUER ALUMINUM FLATBED TRAILER (A59910)
2015 REITNOUER...
Arrow Quip RLDR Alleway Roll Door (A64047)
Arrow Quip RLDR...
2019 FREIGHTLINER 126 SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A64194)
2018 Freightliner...
