Oil & Fuel Diesel additive or not?
   / Diesel additive or not? #1
Jeffery8mm
Mississippi
I have a 3510 4x4 hst and want to know if any of you guys add anything to your diesel?? I have been told with the low sulfer fuel, that it would not be a bad idea to add something. The "something" that has been suggested is everthing from a brand name diesel additive to sea foam to good ole dexron trans fluid!!!! What are yalls thought and suggestions?? I usually run through the fuel in the tank pretty often in the summer and not so often from Nov to Feb.
Jeff
   / Diesel additive or not? #2
   / Diesel additive or not? #3
I add Opti-Lube XPD. It is probably not necessary. But, it really does not cost that much to add some to each tank of fuel. I figure it is cheap insurance.
Be careful what you add, ULSD is completely different. This study showed some of the old standby's actually made the lubricity issues worse. http://www.dieselplace.com/forum/showthread.php?t=177728
Many products have been reformulated since then, to work in ULSD. Check the label.
   / Diesel additive or not? #4
Power Service, white bottle, winter dose - year round
   / Diesel additive or not? #5
I only use the Power Service in the winter but in summer and winter I make sure that I get all my diesel from a station that has a high turnover in fuel, in my case a BP truck stop.
   / Diesel additive or not? #6
Outboard motor (2 cycle) oil....
   / Diesel additive or not? #7
I've used a lot of them and FPPF is the only one that I can actually feel a difference using.
The other don't seem to do anything.
   / Diesel additive or not? #8
1* trans fluid.
2*I usually run through the fuel in the tank pretty often in the summer and not so often from Nov to Feb.
Jeff
1*There is no way I'd put trans fluid in my fuel. :cool:
2*How manny gallon does your tank hold?
About how manny gallon a month do you use?
3*Are you running the red fuel in your tractor.
*Power Service, white bottle, winter dose - year round
*I run a quart of Power Service , white bottle, in each 55 gallon drum of red off road fuel year round.
Went with the Power Service white bottle!!
Thanks
Jeff
   / Diesel additive or not? #10
Hey TYDP.. tried to reply to your PM.. but your PM is bouncing...
soundguy
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
Honda Pioneer 700 Utility Cart (A56857)
Honda Pioneer 700...
2012 GALLEGOS 130 BBL STEEL VACUUM TRAILER (A58214)
2012 GALLEGOS 130...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A56438)
2017 Yale GLC050VX...
2008 KENWORTH T300 FLATBED FUEL TRANSPORT TRUCK (A58214)
2008 KENWORTH T300...
