Oil & Fuel Diesel additive or not?
   / Diesel additive or not? #1
Jeffery8mm
Mississippi
I have a 3510 4x4 hst and want to know if any of you guys add anything to your diesel?? I have been told with the low sulfer fuel, that it would not be a bad idea to add something. The "something" that has been suggested is everthing from a brand name diesel additive to sea foam to good ole dexron trans fluid!!!! What are yalls thought and suggestions?? I usually run through the fuel in the tank pretty often in the summer and not so often from Nov to Feb.
Jeff
   / Diesel additive or not? #2
   / Diesel additive or not? #3
I add Opti-Lube XPD. It is probably not necessary. But, it really does not cost that much to add some to each tank of fuel. I figure it is cheap insurance.
Be careful what you add, ULSD is completely different. This study showed some of the old standby's actually made the lubricity issues worse. http://www.dieselplace.com/forum/showthread.php?t=177728
Many products have been reformulated since then, to work in ULSD. Check the label.
   / Diesel additive or not? #4
Power Service, white bottle, winter dose - year round
   / Diesel additive or not? #5
I only use the Power Service in the winter but in summer and winter I make sure that I get all my diesel from a station that has a high turnover in fuel, in my case a BP truck stop.
   / Diesel additive or not? #6
Outboard motor (2 cycle) oil....
   / Diesel additive or not? #7
I've used a lot of them and FPPF is the only one that I can actually feel a difference using.
The other don't seem to do anything.
   / Diesel additive or not? #8
1* trans fluid.
2*I usually run through the fuel in the tank pretty often in the summer and not so often from Nov to Feb.
Jeff
1*There is no way I'd put trans fluid in my fuel. :cool:
2*How manny gallon does your tank hold?
About how manny gallon a month do you use?
3*Are you running the red fuel in your tractor.
*Power Service, white bottle, winter dose - year round
*I run a quart of Power Service , white bottle, in each 55 gallon drum of red off road fuel year round.
Went with the Power Service white bottle!!
Thanks
Jeff
   / Diesel additive or not? #10
Hey TYDP.. tried to reply to your PM.. but your PM is bouncing...
soundguy
TUGGER TRAILER (A58214)
TUGGER TRAILER...
Hose Reel (A55758)
Hose Reel (A55758)
2020 Club Car Onward HP Li ION Electric Cart. (A56859)
2020 Club Car...
8ft Truck Body Tool Box (A57454)
8ft Truck Body...
2015 TEXAS PRIDE TRAILER  30 FLATBED GOOSENECK TRAILER (A58214)
2015 TEXAS PRIDE...
2012 MCLAUGLIN/VERMEER V800AWXT VACUUM EXCAVATOR (A57880)
2012...
