Did LS take over Montana if so what model replaced 2740?
   / Did LS take over Montana if so what model replaced 2740? #1
Rob50056
Springfield,Mo
John Deere lx288 and 425
I have seen some Montana models replaced by LS but I can稚 find anything about if LS now builds the 2740.
Is been a very solid reliable compact tractor.Picks up big bales,run hogs,attachments,etc...
It痴 Sunday so I値l try calling LS tomorrow but I thought I壇 try the forum.
If anyone knows what model replaced the Montana 2740 please post.
Thanks,
It’s looking like the Montana 2730 has a Daedong 3A139LG engine and so far it’s looking like Kioti might be making it.
I think the Montana LS models were taken over by LS and had Mitsubishi engines??
Anyway I’m trying to find a fuel filter,bowl,o rings,and maybe even a new ring nut for my 2740.
I definitely need a new plastic bowl for it but finding one has turned into a pain.
I wonder if there’s any way to use an inline filter?
There’s 3 hoses going to bowl assembly and maybe once air is out of line I could use a Y on the inlet or outlet side of filter assembly.
   / Did LS take over Montana if so what model replaced 2740? #4
Post a thread in the Montana section about looking for parts rather than asking who owns who.
   / Did LS take over Montana if so what model replaced 2740? #5
Following data should allow you to find contemporary equivalent on LS's web site.
Contemporary LS will be Tier IV emissions compliant.
Montana 2740
2004 - 2009
Compact Utility tractor
Montana 2740 Engine:
Daedong 1.4L 3-cyl diesel
Engine: 27 hp [20.1 kW]
Capacity:
Fuel: 7.4 gal [28.0 L]
3-Point Hitch:
Rear Type: I
Rear lift (at ends): 1596 lbs [723 kg]
Power Take-off (PTO):
Rear PTO: independent
Rear RPM: 540
Dimensions & Tires:
Front tire: 6.0-14.0
Rear tire: 9.5-24.0
Weight: 2600 lbs [1179 kg]
Length: 115.4 inches [293 cm]
Height: 93.2 inches [236 cm]
Ground clearance: 11.6 inches [29 cm]
4WD turn radius: 9.6 feet [2.9 m]
Mechanical:
Chassis: 4x4 MFWD 4WD
Steering: power
Brakes: wet disc
Cab: Two-post fixed ROPS.
Hydraulics:
Valves: 1
Pump flow: 5.76 gpm [21.8 lpm]
Page information:
Last update: December 20, 2018
Copyright: Copyright 2018 TractorData LLC
Contact: Peter@TractorData.com
It turns out it’s owned or was owned by several companies SK,LS, and parts for Kioti CK25 will do the repair this time.
   / Did LS take over Montana if so what model replaced 2740? #7
Montana 2740 engine:
Daedong 3A139LG
diesel
3-cylinder
liquid-cooled
85.43 ci [1.4 L]
Kioti CK27 engine
Daedong 3A139LWM
diesel
3-cylinder
liquid-cooled inline
85 ci [1.4 L]
Daedong 3A139LG
diesel
3-cylinder
liquid-cooled
85.43 ci [1.4 L]
Kioti CK27 engine
Daedong 3A139LWM
diesel
3-cylinder
85 ci [1.4 L]
Thanks for correction.
The part I知 needing,fuel filter assembly fits CK,DK,DS and DL models.
If I need engine parts or more parts knowing that it痴 a CK27 will come in helpful.
BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox XHD72...
2013 Cadillac SRX SUV (A53424)
2013 Cadillac SRX...
(9) ROLLS OF 5' - 10 GAUGE CONCRETE WIRE (A54757)
(9) ROLLS OF 5' -...
Honda Pioneer SXS700 4X4 Utility Cart (A55758)
Honda Pioneer...
2016 CATERPILLAR D5K2 XL CRAWLER DOZER (A52706)
2016 CATERPILLAR...
2014 Nissan Juke (A55758)
2014 Nissan Juke...
