Did LS take over Montana if so what model replaced 2740?
   / Did LS take over Montana if so what model replaced 2740? #1
Rob50056
Springfield,Mo
John Deere lx288 and 425
I have seen some Montana models replaced by LS but I can稚 find anything about if LS now builds the 2740.
Is been a very solid reliable compact tractor.Picks up big bales,run hogs,attachments,etc...
It痴 Sunday so I値l try calling LS tomorrow but I thought I壇 try the forum.
If anyone knows what model replaced the Montana 2740 please post.
Thanks,
It’s looking like the Montana 2730 has a Daedong 3A139LG engine and so far it’s looking like Kioti might be making it.
I think the Montana LS models were taken over by LS and had Mitsubishi engines??
Anyway I’m trying to find a fuel filter,bowl,o rings,and maybe even a new ring nut for my 2740.
I definitely need a new plastic bowl for it but finding one has turned into a pain.
I wonder if there’s any way to use an inline filter?
There’s 3 hoses going to bowl assembly and maybe once air is out of line I could use a Y on the inlet or outlet side of filter assembly.
   / Did LS take over Montana if so what model replaced 2740? #4
Post a thread in the Montana section about looking for parts rather than asking who owns who.
   / Did LS take over Montana if so what model replaced 2740? #5
Following data should allow you to find contemporary equivalent on LS's web site.
Contemporary LS will be Tier IV emissions compliant.
Montana 2740
2004 - 2009
Compact Utility tractor
Montana 2740 Engine:
Daedong 1.4L 3-cyl diesel
Engine: 27 hp [20.1 kW]
Capacity:
Fuel: 7.4 gal [28.0 L]
3-Point Hitch:
Rear Type: I
Rear lift (at ends): 1596 lbs [723 kg]
Power Take-off (PTO):
Rear PTO: independent
Rear RPM: 540
Dimensions & Tires:
Front tire: 6.0-14.0
Rear tire: 9.5-24.0
Weight: 2600 lbs [1179 kg]
Length: 115.4 inches [293 cm]
Height: 93.2 inches [236 cm]
Ground clearance: 11.6 inches [29 cm]
4WD turn radius: 9.6 feet [2.9 m]
Mechanical:
Chassis: 4x4 MFWD 4WD
Steering: power
Brakes: wet disc
Cab: Two-post fixed ROPS.
Hydraulics:
Valves: 1
Pump flow: 5.76 gpm [21.8 lpm]
Page information:
Last update: December 20, 2018
Copyright: Copyright 2018 TractorData LLC
Contact: Peter@TractorData.com
It turns out it’s owned or was owned by several companies SK,LS, and parts for Kioti CK25 will do the repair this time.
   / Did LS take over Montana if so what model replaced 2740? #7
Montana 2740 engine:
Daedong 3A139LG
diesel
3-cylinder
liquid-cooled
85.43 ci [1.4 L]
Kioti CK27 engine
Daedong 3A139LWM
diesel
3-cylinder
liquid-cooled inline
85 ci [1.4 L]
Daedong 3A139LG
diesel
3-cylinder
liquid-cooled
85.43 ci [1.4 L]
Kioti CK27 engine
Daedong 3A139LWM
diesel
3-cylinder
85 ci [1.4 L]
Thanks for correction.
The part I知 needing,fuel filter assembly fits CK,DK,DS and DL models.
If I need engine parts or more parts knowing that it痴 a CK27 will come in helpful.
U56 ELECTRIC FIRE PUMP MOTOR (A51406)
U56 ELECTRIC FIRE...
UNUSED FUTURE ZWB MINI BACKHOE DIGGER ARM (A54757)
UNUSED FUTURE ZWB...
9202 (A50322)
9202 (A50322)
2014 Walker Walk-Behind Vibratory Plate Compactor (A55787)
2014 Walker...
2006 FREIGHTLINER CL120 DAY CAB (A53426)
2006 FREIGHTLINER...
