Mowing Did I mess up my cutter?
   / Did I mess up my cutter? #11
On my "hog", there's a check plug about 1/3 to 1/2 way up one side and a vent on the top. For filling, the vent is the easiest to use. Just fill from there but with the lower plug removed.
For suctioning oil or brake fluid, I use a MiniVac. You can also get something like a Pela extractor that many use to remove motor oil on vehicles that have a bottom shield in place. I've gonna get one to remove oil from my generator because I made a mess the one and only time I drained it out onto the ground (no way to get anything under it). Will need it later to change the oil on our VW TDI after the 3 years' worth of free service is run out.
If none of your seals are leaking now, doubt you did any damage.
Ralph
2018 Dodge Journey SUV (A50324)
2018 Dodge Journey...
200 Gallon 3-point Sprayer 30ft Boom (A52128)
200 Gallon 3-point...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52128)
REYNOLDS 100 - 8...
WOLVERINE PAB-11-72W HYD QUICK ATTACH ANGLE BROOM (A51244)
WOLVERINE...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
