Did I buy the wrong generator?
   / Did I buy the wrong generator? #101
Just how do you get a generator excited?:D Well first you could try plying it with alcohol, soft music and low lighting.:)
We have one electrician at work that we like to call in when we have "excitation problems", generator or otherwise... to say that she is an attractive young lady is a bit of an understatement. I think she's getting tired of us asking if she would "give the generator a little rub" to get it in the mood.
Sean
   / Did I buy the wrong generator? #102
Sean
Oh Man, ROFL! thanks for jumping in.. I was having a hard time trying to convince QRTRHRS that I wasn't just making this "excitation" thing up. I mean after all how do you get excited about a generator.. or whatever:laughing:
I would like to meet that electrician by the way:D
James K0UA
   / Did I buy the wrong generator? #103
I know it's legit from hearing about it in other generator threads, just never seen it myself.
I have seen gennys come out of 20 year storage and not have the problem, so it is not happening to all generators just because they have been unused for awhile.
JB
   / Did I buy the wrong generator? #104
We live off grid, new house with new appliances and fairly sensitive electronics. We started with a Honda EB3000 running 4-8 hours per day depending on season & amount of daylight. After many-many thousands of hours [with proper maintainance, the genny needed servicing. We were without a generator for all of six hours, we bought a Champion 4000 from tractor supply for $299. In the first six hours of running we figured out running that Champion produced different power than the Honda. Our 1 year old front-load washing machine was fried, two PC's lost their power-supplies, and our 32" LCD flat-screen was TOAST! So, we borrowed another brand 5000 watt to run what was left, pump-lights-etc...
We have since bought the Honda EU3000 (and replaced most of the electronics thanks to add-on service plans and warranties), now using the old EB3000 for a spare/back-up. Turns out the frequency was WAY OFF (supposed to be 60 cycles) on the cheaper genny's from 40 to 90 cps.
If you wish to run the newer appliances and electronics without killing them with the generator, you should find a way to get cleaner power by buying a generator with a built in inverter or run the genny-power through a pure-sine-wave inverter/charge controller.
ANY generator can run a Skil-saw and lights! It's amazing the number of house-hold items have circuit boards in them and the damage that can be caused by a "cheap" generator!
Also, if a generator will produce the majority of power (running most of the time you're on location) you should consider propane fuel. You will use less fuel, have less carbon deposits and longer engine life. Not to mention the propane guy can fill a 100 or 250 gallon tank [pig] about twice per year and you don't have to "fill & spill" those 5 gallon gas/diesel cans!
We live off grid...
That is so cool!
I'm jealous.
There are days I want to lock the main gate and tell the world to go hang...
Welcome to TBN. I look forward to hearing more and seeing PICTURES!
Be well,
David
   / Did I buy the wrong generator? #106
How much fuel did the EU3000 burn per week if you ran it between 6 to 8 hours per day.
I would think that could get expensive.
   / Did I buy the wrong generator? #107
Start a thread on your experiences. When you are off the grid the inverter generator saves so much on engine wear and fuel it's a gotta have.
   / Did I buy the wrong generator? #108
I've been giving some thought to getting a smaller generator, something in the 3000-3500 watt inverter range should do the trick. The EZ5000, while bulletproof, produces dirty power and is noisy.
It's not really a high priority for me, but I'd like to find someone that bought one and found it to be too small for their use.
Sean
   / Did I buy the wrong generator? #109
James K0UA
Next time we need something "excited" I'll ask her if she minds if I take a picture of her giving the generator a "come-hither" look. Good chance I'll be un-employed or injured shortly afterwards, so I may wait until I'm closer to retirement.
Sean
   / Did I buy the wrong generator? #110
TimberXX, the run-time on the EU3000 *on eco-throttle* is supposed to be 21 hours... we get between 18 and 21 hours most of the time. Our genny gas bill is around $120 to $180 per month since I make a conscious effort to reduce run time.
Laundry [with 110v water pump] takes high throttle but it's once a week a for a few hours. I'm planning to replace that well pump to a 'slow-start' solar friendly pump in the spring. In March we should have ten 235 watt solar panels assembled in the yard and a 3K Outback inverter all set up to cut way back on the gas bill.
Converting a non-solar built house is costly, I built ours to be mostly solar so everything is handled nicely with the EU3000.
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A52128)
2022 Gravely...
CASE 580M TURBO BACKHOE (A51242)
CASE 580M TURBO...
UNUSED CFG Industrial QK18R Mini Excavator (A47384)
UNUSED CFG...
TEST BID LOT (A50774)
2015 Ford Escape 4x4 SUV (A50324)
2015 Ford Escape...
