Deutz Hydaulics/Power steering
   / Deutz Hydaulics/Power steering #1
BIGCRYER
Deutz 4006
Have a Deutz 4006. Installed a new hydraulic pump, the old one was shot, and have not been able to get the new pump to work consistently. Have tried a number of thing that were suggested locally, but either get a cycle or two or no results. Has anyone had/solved a similar problem.
   / Deutz Hydaulics/Power steering #2
I can't tell if you said it ran any length of time, or it turned a few times and lost its prime. Is the circuit complete such as pump to valve, cylinder/motor, etc? Did you fill the pump to start with. A gear pump should self prime if not too much height difference.
It was just a few cycles. I am wondering if the oil lines have a leak in them so that the pump won't prime. I was someone had a tweak that would correct the problem. Thanks for your suggestions.
   / Deutz Hydaulics/Power steering #4
You could have lost your prime due to an air leak. Replace the suction hose or tighten it some more.
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
(30) 24-A Macro Bins (A50121)
(30) 24-A Macro...
MILLER BIG BLUE 500 PRO TOWABLE WELDER (A52472)
MILLER BIG BLUE...
Unused 2025 CFG QK16R Mini Excavator (A50322)
Unused 2025 CFG...
