Deutz Hydaulics/Power steering
   / Deutz Hydaulics/Power steering #1
BIGCRYER
Deutz 4006
Have a Deutz 4006. Installed a new hydraulic pump, the old one was shot, and have not been able to get the new pump to work consistently. Have tried a number of thing that were suggested locally, but either get a cycle or two or no results. Has anyone had/solved a similar problem.
   / Deutz Hydaulics/Power steering #2
I can't tell if you said it ran any length of time, or it turned a few times and lost its prime. Is the circuit complete such as pump to valve, cylinder/motor, etc? Did you fill the pump to start with. A gear pump should self prime if not too much height difference.
It was just a few cycles. I am wondering if the oil lines have a leak in them so that the pump won't prime. I was someone had a tweak that would correct the problem. Thanks for your suggestions.
   / Deutz Hydaulics/Power steering #4
You could have lost your prime due to an air leak. Replace the suction hose or tighten it some more.
2000 2 Axle Deckover Trailer (TITLE) (A50774)
2000 2 Axle...
2007 IC Corporation PB105 Passenger Bus (A51692)
2007 IC...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A51692)
2013 Ford F-150...
2006 John Deere HPX Gator 4x4 Utility Cart (A50322)
2006 John Deere...
Rhino V152 (A50121)
Rhino V152 (A50121)
2012 Chevrolet Cruze LS Sedan (A50324)
2012 Chevrolet...
