Deutz Fahr Agrotron 135 Mk3 doesn't start
   / Deutz Fahr Agrotron 135 Mk3 doesn't start #1
LukeLukas
This occurred 2 days ago and since then have not been able to turn on the tractor. When you turn on the ignition everything lights up as it usually does, no emergency lights no errors, just doesn't start when you turn the key, the starter doesn't even click, there is nothing, no sound. Anyone might have any idea what could be the problem? Also, the tractor is newly bought for our farm, we have had it for literally a week.
   / Deutz Fahr Agrotron 135 Mk3 doesn't start #2
Not familiar with the wiring on your tractor but it sounds like a safety switch is open or bad relay. Of course start with testing the battery and cleaning all the cable connecting points.
If you can be certain the tractor is not in gear and it can not move, you could try jumping the starter solenoid and see if it will start. But this bypasses all safety switches so be careful.
   / Deutz Fahr Agrotron 135 Mk3 doesn't start #3
Switch on but do not start . Check on pad for a little red light blinking . Count those blinkes to get the code.
   / Deutz Fahr Agrotron 135 Mk3 doesn't start #4
Make sure the negative battery cable is well attached to a grounding point.
2013 NISSAN NV3500 CARGO VAN (A59575)
2013 NISSAN NV3500...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Can-Am Defender 11000 (A59814)
Can-Am Defender...
KAWASAKI 42ZV WHEEL LOADER (A60429)
KAWASAKI 42ZV...
UNKONW  SPOOL TRAILER (A58216)
UNKONW SPOOL...
2024 CATERPILLAR 255 SKID STEER (A52707)
2024 CATERPILLAR...
