Deutz 6206 starting
/ Deutz 6206 starting
Wiring diagram in owners manual leaves a lot to be desired.
On starter pull out switch it's supposed to be first click out is pre-heat and all the way out engages the starter. On mine it's backward.
Key switch on mine is first click turns on tail lights - second position turns on
gen. and oil lights and third position enables starter pull on switch to engage
starter.
I am ordering electrical manual because almost all the wiring on mine has been disconnected.
I am an electronic engineer and found the rudimentary diagram in the owners
manual tough to decipher.
Lots of luck on your purchase. I have to split mine because the front transmission seal is leaking so the electrical problems, right now, are secondary.
I apologize! Checked manual and there is front wheel info.
I will send you a copy of the pages if you will provide an email address.
Jim
/ Deutz 6206 starting #13
starter.
I don't even have a key switch! Just a toggle to turn on the electrical.
Sounds familiar...
Ouch! Good luck with that. It sounds like a serious undertaking.
(1) Camso 15-19.5 Foam Filled Tire (A60463)
(1) Camso 15-19.5...
Deere 333E (A60462)
Deere 333E (A60462)
2011 TRAIL KING INDUSTRIES PNEUMATIC TRAILER (A60736)
2011 TRAIL KING...
LMC Ag 25 Gallon Sprayer (A60463)
LMC Ag 25 Gallon...
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
2018 FORD F-250 XL SUPER DUTY EXT CAB TRUCK (A59823)
2018 FORD F-250 XL...
