Deutz 4 cyl. diesel start, stall, run slow, stop, repeat
   / Deutz 4 cyl. diesel start, stall, run slow, stop, repeat #41
Only want it to help with fuel filter change.
   / Deutz 4 cyl. diesel start, stall, run slow, stop, repeat #42
   / Deutz 4 cyl. diesel start, stall, run slow, stop, repeat #43
Could not do that, not enough room between filter and pump.
I thought of putting in a shutoff also but then I decided I didnt want to introduce another failure point in the system.
Below is a link to what I used and I just keep them handy. Pick the right size and then it just clamps down over the fuel line and shuts off the flow when necessary.
   / Deutz 4 cyl. diesel start, stall, run slow, stop, repeat #45
@m5040 Then is one on each side of the filter better?
It shouldn't need one on the other side of the filter. It would be the same theory as putting a straw in your drink and when you cap off the top of the straw, you can lift it out without loosing any liquid. Obviously the fuel tank side needs one (or a clamp) because the tank is vented, like taking your finger off the straw.
   / Deutz 4 cyl. diesel start, stall, run slow, stop, repeat #46
Fortunately, the Deutz engine's fuel system is self priming so air in the fuel lines is not a problem.
   / Deutz 4 cyl. diesel start, stall, run slow, stop, repeat #47
Put a new o ring on and it seems to have stopped the leak, we used it for about 3 hours mowing with no problems.
2016 Case CX55B Midi Excavator (A55973)
2016 Case CX55B...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
2013 Chevrolet Express 3500 Passenger Van (A55973)
2013 Chevrolet...
2012 FORD F450 XL SUPER DUTY TRUCK (A51406)
2012 FORD F450 XL...
2006 Chevrolet Express 3500 Versalift Vantel29N 29ft Bucket Van (A56858)
2006 Chevrolet...
