Deutz 3006 PTO Question
   / Deutz 3006 PTO Question #1
rickyb01
Mayflower
1976 Deutz 3006 1962 John Deere 1010
I have a 60's model 3006 that jumps out of PTO gear while bushhogging. This just started over the weekend but while you are bushhogging it will start grinding and making a heck of a noise. You push in on the clutch and engage the pto again it goes in smooth with no grinding and start bushhoggin and withing 10 minutes it starts grinding and has popped back out. Is this maybe worn out PTO gears. Sorry but not very mechanical so just trying to get a place to start troubleshooting. Thanks for all the help in advance. Rick
   / Deutz 3006 PTO Question #2
I'd say the forks (for lack of a better term) is worn, you will have to go into it to see "exactly" what is worn and letting it work "out of" gear.
SR
Thanks for the response Sawyer Rob.
does anybody know if this will all come out the back of the pto or will I have to split it to look at it?. Sorry don't have any experience with deutz. Even though I have owned this tractor for 10 years I have never had to work on it. Thanks Rick
   / Deutz 3006 PTO Question #5
I think you can drain the tranny, take the seat off, pull the cover under the seat and see what's going on.
At least, that's what I remember...
While you are in there, look for a plastic ? basket strainer in there. Clean it good before closing everything back up.
SR
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
