Determining motor/pump size
/ Determining motor/pump size #21
What is wrong with the existing hydraulic motor? Any reason you cant use it as is?
now if it is worn out I would consider crossing over to a Commercial Shearing motor with the similar specs. These are good quality and also available with the end fed hoses.
It appears that this deck was driven by a PTO shaft. He added the motor, hoping it would work, and it may work, if he has a pump that can supply the correct amount of hyd fluid to the motor. He is also not sure about the max rpm that the TORO deck was designed to run. There are a lot of ifs here. dodge85rc is trying to make something, with what he has.
No there is nothing wrong with it. Now that it has been determined that is big enough I plan on using it. On to the pump now...
THe max rpm at the pto shaft end of the gearbox was 2700 rpm. I thought I posted that before, maybe I forgot.
/ Determining motor/pump size #24
dodge85rc,
You did post earlier, that your brother said it ran at 2700 rpm. I went back and read all the post again.
You also said the speed of the deck was 1800, and the gearbox was 1 : 1
So I need a pump then that will pump out at least 10 gpm to drive the motor?
/ Determining motor/pump size #26
Looks like you want about 15 p[m from the pump but if you are using a 100 hp engine you need to decide what the engine rpms are going to be, what the output shaft to the pump will be, then pick a pump who''s flow is correct.
I picked up a couple of big hydraulic clutch pumps. Need some help figuring out specs.
First one is a borg-warner, number on it is s20517dh81r
Haven't found the numbers on the 2nd one yet...
/ Determining motor/pump size #28
Did you settle on any particular HP? If you are thinking high HP, then any number of pumps would work.
You can either test those pumps your self, or let a hydraulic shop test them for you. They should be able to give you operating pressure, GPM, and direction of rotation.
I'm sorry I'm not following, hp for what, the engine?
/ Determining motor/pump size #30
Yes, the HP on the engine. You had mentioned a 100 HP engine, and a smaller engine at another time. The HP available will be the limiting factor in the pump size utilized, and that figure will transfer to the HP that the hydraulic motor will develop.
Ok, I am using the 100 hp engine.
The smaller 20 hp one I was going to use will be put back on the shelf and saved for when I can find a generator head somewhere...
/ Determining motor/pump size #32
The deck you are using was probably designed for a blade tip speed of 13000ft/min (~65m/s), this is the max speed allowed under either UK or USA standards hence is the normal target speed.
If you are planning to cut thick wet grass or vegitation then I would suggest a target of atleast this.
From the picture of the deck you posted earlier I suspect that the limiting factor in the power you can use will be the belt drive. This can be calculated from the belt size and pulley contact angles I think, try a web search for full details. I would try and deliver the maximum torque that the belt can transmit to enable a fast acceleration of the cutters when started in the grass.
/ Determining motor/pump size #33
If the blade's are 25 in long, then the circumference is 78.5 in, x 1800 rpm = 141,300 in per min divided by 12 in = 11, 775 ft/min.
25 in would allow some overlap to give a 72 in cut. If they are 26 or 27, in, then the blade tip velocity will be greater.
/ Determining motor/pump size #34
From J.J.'s calcs above then 1800rpm would work with 25 in blades but personally I would try for more, in my experience of cutting in UK conditions the extra blade speed makes a real difference in the cutting and discharge of the cut material.
If you want to judge the power available then put a pressure meter in the motor supply line and try cutting, there should be a reading for just turning the blades which will increase when cutting. The difference between the cutting and maximum will indicate the surplus power
Wow, there is getting to be way more math involved than I ever would have thought! I do plan on putting a flow control valve on line going to the motor so that I can adjust the rpm to the desired speed. Still waiting to hear back from the manufacturer about that big clutch pump I got. I would guess it should be sufficient, it has a 1 1/2" outlet on it.
/ Determining motor/pump size #36
Although pump volume is a good thing when needed, all those excess GPM not being used is going to cause some design problems. Most manufactures only use a pump large enough to get the job done, and then they have to figure the cooling required for that much volume, and size of the reservoir, will a radciator be required. etc. So extra large is not good sometimes. Sure, you can install a flow control and vary the speed, but the size of the motor in cu in and GPM will determine the rpm of the motor. After everything is put together, how are you going to determine the speed of the hyd motor. Any fluid not used by the hyd motor, is a heat source.
/ Determining motor/pump size #38
dodge85rc,
On my Power-Trac, My engine turns four pumps that pump a total GPM of about 22.
My reservoir is 20 Gal of 10W-30 motor oil, which is used as hyd fluid. It also has a hyd cooling radiator, and fan. The sides of the reservoir still get plenty hot.
/ Determining motor/pump size #39
Dodge85rc
I assume that you are planning to use the tractor with other machines in the longer term, so have you thought about using a single variable displacement pump. This would enable you to run the engine at a lower speed and still drive a high speed implement or run at full engine speed and not waste power pumping heat into the hydrualic oil.
Such pumps are often used on the land drive units of mowers or excavators.
/ Determining motor/pump size #40
dodge85rc, said, This is for a home build custom tractor I am building.
So far he has only talked about the motor/pump combination to drive the deck. He has also said he is going to use about a 100 HP engine. Yes, he will have to come up with a way to drive his machine, either gear transmission, or hydrostatic transmission. It is not as simple as some might think, like how much does the machine weigh when finished. How much HP/torque is required to turn the wheels at a certain rpm to give a working speed of XX. Then you have the engine cooling, fan, hyd cooling /fan, hoses, valves, steering, size of the tires, width of tire. turf tread, or tractor tread, tire pressure. Is it being designed for a FEL, or 3pt system. How is he going to steer the machine, like a tractor, or swivel in the middle and steer with hyd cylinders, like a Power-Trac. How many valves will be necessary. Will hyd wheel motors be used.
Sometimes you can just throw things together, and it might work good, but in most cases, poor planning will cause one to grab this, grab that, slap it all together, and hope for the best.
A carefully thought out plan, financial considerations/budget, time factor, mechanical aptitude, electrical knowledge, welding ability, all have to be considered.
Any idea how much 20 gal of hyd fluid weigh, and how much oil can be filtered in an hour, What kind of hyd fluid will be used? Will it have a ROPS system?
Really, a lot of things to be considered. Patience, time, knowledge, and the financial
aspect will determine the successful conclusion of this endeavor.
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
2011 CAT 430E BACKHOE LOADER (A65643)
2011 CAT 430E...
BG PF5 HIGH OUTPUT POWER FLUSH AND FLUID EXCHANGE SYSTEM (A65643)
BG PF5 HIGH OUTPUT...
2025 TEXAS PRIDE 14FT T/A DUMP TRAILER (A59914)
2025 TEXAS PRIDE...
New/Unused Landhonor 72in Rock Bucket with Teeth (A65583)
New/Unused...
New/Unused Spirit Electric Tricycle (A65583)
New/Unused Spirit...
