Desiel can
   / Desiel can #3
Crikey! That looks like what they use in the pits for the various racing cars 'codes'.
Mind you, anything that can't be sold in California can't be all bad. :rolleyes:
   / Desiel can #4
That doesn't look like it would be much fun trying to fill a tractor with 5 gallons of diesel. Using it on a vehicle at waist height with a fill hole that's at an angle might not be so bad, but lifting it up to fill a horizontal fill hole on a tractor wouldn't be pleasant. You'd be better off using a cheaper can and removing the nozzle to dump it into a funnel. No Spill brand cans are about the same price and work well filling a tractor if you have a good place to set the can while you hold the button.
   / Desiel can #6
I use a big funnel and screw the top off my can as I hate those anti-spill nozzles, but it is a bear lifting a 5 gallon jug up above my chest on my Ford 861D. I bought a cheap HF 12vt. fuel pump to save my aging back, but have not rigged it up yet.
   / Desiel can
I think I might try one, full should only weight about 37 lbs and once you lift it it sits right on your tank which then takes the weight. I hate funnels, I have the no spill brand now but so slow.
   / Desiel can #10
Self-Priming Copper Jiggler Pump
Works for me, I'm too old to lift fuel cans that high.
2016 Chevrolet Traverse LS SUV (A53117)
2016 Chevrolet...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A55301)
2016 KBH...
2015 Land Rover Evoque SUV (A53424)
2015 Land Rover...
2016 FORD F250 XL SUPER DUTY TRUCK (A51406)
2016 FORD F250 XL...
2007 CHEVROLET C4500 DUMP TRUCK (A51406)
2007 CHEVROLET...
2017 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A54313)
2017 FREIGHTLINER...
