Desiel can
   / Desiel can #3
Crikey! That looks like what they use in the pits for the various racing cars 'codes'.
Mind you, anything that can't be sold in California can't be all bad. :rolleyes:
   / Desiel can #4
That doesn't look like it would be much fun trying to fill a tractor with 5 gallons of diesel. Using it on a vehicle at waist height with a fill hole that's at an angle might not be so bad, but lifting it up to fill a horizontal fill hole on a tractor wouldn't be pleasant. You'd be better off using a cheaper can and removing the nozzle to dump it into a funnel. No Spill brand cans are about the same price and work well filling a tractor if you have a good place to set the can while you hold the button.
   / Desiel can #6
I use a big funnel and screw the top off my can as I hate those anti-spill nozzles, but it is a bear lifting a 5 gallon jug up above my chest on my Ford 861D. I bought a cheap HF 12vt. fuel pump to save my aging back, but have not rigged it up yet.
   / Desiel can
I think I might try one, full should only weight about 37 lbs and once you lift it it sits right on your tank which then takes the weight. I hate funnels, I have the no spill brand now but so slow.
   / Desiel can #10
Self-Priming Copper Jiggler Pump
Works for me, I'm too old to lift fuel cans that high.
CATERPILLAR 631E SERIES II MOTOR SCRAPER (A52706)
CATERPILLAR 631E...
2022 Big Tex 22GN-35BK+5MR 40ft T/A Gooseneck Equipment Trailer (A51691)
2022 Big Tex...
UNUSED PE Industrial Stretch Wrap Rolls (A53117)
UNUSED PE...
2007 OVERLAND  TANK TRAILER (A53843)
2007 OVERLAND...
2 pair -st205/75r15 radial trailer tires (A53421)
2 pair...
2001 CATERPILLAR 908 LOADER (A51406)
2001 CATERPILLAR...
