Delivery pipe
/ Delivery pipe #1
mrtrathen
TYM T353HST
Greetings all, I have a leaky delivery pipe. The pipe comes from the HST to the FEL. The part number is 13025134600. I can't find any where that has it. Tractor is a T353 HST. #8
/ Delivery pipe #2
Many shops that specialize in hydraulic hoses also do ridgid line.
I just had 3 made last week.
Now I need to take one back to bend one bend a little more.
To be fair it was twisted and cut in half.
/ Delivery pipe #3
The cold drawn seamless tubing (stainless steel) for hydraulic lines, I used to purchase at a Parker supply house.
I would suggest that you cut the portion out that has the leak and buy some tubing and a couple hydraulic compression fittings to replace the section you have removed.
That will be much less labor than trying to replace the whole line.
/ Delivery pipe
MAX,
The leak is at the end of the pipe where it fits into the FEL diverter. It's at the neck of the compression fitting.
/ Delivery pipe #5
Also, if you replace metal pipe with hydraulic hose you will have an increase in hydraulic temperature. The pipes preform some cooling effect, some manufacturers rely on this.
/ Delivery pipe #6
MAX,
That sounds like an assembly error from the loader manufactuer. Unless it was hit with something that was getting moved.
For me, I would identify the fitting type and call the nearest Parker supply house to confirm they have stock. It would be a 2 1/2 hour one way trip for me. Well worth the time as far as I'm concerned.
Ask them if they have dies for bending your size hydraulic pipe, I would still cut the pipe off and take it to them to match the shape.
Like @404nouser says, it may be easier to replace the section with hydraulic hose. 2 to 3 feet at 2700psi is not going to add much heat. If you go the hose route you may want to consider a wrap to lower abrasion from vibration and kinetic forces at the new fitting locations.
2019 INTERNATIONAL HV613 6x4 T/A SERVICE TRUCK (A67148)
2019 INTERNATIONAL...
2019 KUBOTA KX71-3 SUPER SERIES EXCAVATOR (A65053)
2019 KUBOTA KX71-3...
KUBOTA KX033-4 EXCAVATOR (A64279)
KUBOTA KX033-4...
2018 Kenworth T800 T/A Sleeper Cab Truck Tractor (A64194)
2018 Kenworth T800...
2022 EZ-GO ELITE...
2016 Chevrolet Silverado 3500 Auto Crane Service Crane Truck (A64194)
2016 Chevrolet...
