Dehumidifier Recommendations
   / Dehumidifier Recommendations #1
DrRod
Platinum Member
Ellicott City, MD - Farm in Orbisonia PA (south ce
John Deere 4110
My friend has a damp basement and wants to get a good dehumidifier. Its a sizable cape cod house and the basement is finished. It is fully underground with a door to a set of steps leading up to ground level. Is there a good portable unit that will do the job is it the kind of thing that only a professionally installed model will handle. She has hot water heat so I don't think its anything that can be added to the furnace -- but I really don't know. Thank you for your help.
   / Dehumidifier Recommendations #2
We have this one and it works extremely well. You can attach a hose and run it to a drain and you don't have to empty it. Or, you can empty it manually. You select the humidity level you want and it will keep it there so that it does not have to run continuously.
   / Dehumidifier Recommendations #3
We have had 3 inexpensive GE brand dehumidifiers bought at Sam's Club. They work terrific, BUT, the compressors (Chinese made) in two of them have quit and they are uneconomical to repair. Get the 3-year extended warranty and you should be good. They are really just little window air conditioners with a more sophisticated condensate catch system.
- Jay
   / Dehumidifier Recommendations #5
   / Dehumidifier Recommendations #6
I have a Frigidaire FAD704DWD Energy Star 70-pint Dehumidifier that I purchased from Kmart
three years ago and it has worked fine keeping the humidity under control in my 48' x 26'
full basement. It also has a hose connection on the back to drain the water, eliminating the
need for emptying the container once or twice a day.
   / Dehumidifier Recommendations #7
Thanks for the info. Can you tell me about how much space you are working with?
We currently have ours in our ~1200 sq. ft. basement garage with concrete on 3 sides. It has no trouble keeping it at 50%.
   / Dehumidifier Recommendations #8
Have one of the GE models from Home Depot, the middle size. Has worked fine for 2+ years so far.
   / Dehumidifier Recommendations #9
Our basement is roughly 800 sq ft. Also used it in a small house for a while. About 1000 sq ft.
- Jay
2016 CATERPILLAR 262D WHEELED SKID STEER (A51242)
2016 CATERPILLAR...
1.5 Rolls of Red Brand Barb Wire (A50515)
1.5 Rolls of Red...
2015 Freightliner Cab & Chassis (A47384)
2015 Freightliner...
2004 30ft S/A Scissor Pontoon Boat Trailer (A50324)
2004 30ft S/A...
2019 FORD F550 XL SERVICE TRUCK (A51243)
2019 FORD F550 XL...
New Wolverine Skidloader Sickle Bar Mower (A50774)
New Wolverine...
