Define CUT?
/ Define CUT? #1
Charlie175
Virginia
Mahindra 2015 gear
What separates a Sub CUT from a CUT from a Utility?
Size I would assume, but take example a IH 140 tractor, which in todays world would be a CUT?
/ Define CUT? #2
These are separated by grey lines, not black and white.
It sort of reminds me of parking spaces for "compact cars". Who decides what is what?
In my view, tractors in the 30 +/- 5 HP vicinity are compact. Below that are sub compact. Above that are utility.
I'm not sure what tractor you're talking about, but at least one IH 140 tractor is rated at 100HP which is hardly in the "compact" realm.
/ Define CUT? #3
that would be the simplest "lets not consider anything else" way of looking at it.
second thing i would quickly use to determine is weight. a 40hp CUT and a 40hp small AG tractor... the AG tractor is likely to out weigh it by upwards of 25%. weight being important for draw bar use and mass for things like balers.
Old iron of yesteryear in the 40hp range will dwarf (in weight and size) what a Kubota of nearly identical hp of today.
IMHO a SCUT is anything that (with a MMM and no attachment) you would think is a riding lawnmower if you saw it.
/ Define CUT? #4
TedLaRue said:
These are separated by grey lines, not black and white....
The problem with this definition is that it makes a Ford 9N, etc. a subcompact. I think we need to take tire or frame size into account as well.
/ Define CUT? #5
What problem are we trying to solve by defining SCUT, CUT and Utility tractors?
/ Define CUT?
No problem, just trying to answer in my mind the definition of it.
/ Define CUT? #7
Since there's no standard, each manufacturer defines their tractors differently, depending on whether they are trying to sell the largest SCUT or the smallest, lightest CUT. :D
IMO, what it comes down to is people should buy the tractor they need to complete the tasks they have. This most often means they should focus on the size, weight, horsepower and features of the tractor and not the classification.
/ Define CUT?
I think the SCUT has larger replaced the Garden tractors of yesteryear as many manufactures don't offer a GT line anymore.
/ Define CUT? #9
I agree with schmism's point that horsepower is a very crude measuring stick. I think that's especially true down in the riding lawnmower size machines.
Size, tire size, and weight are also important, but those should roughly correspond to horsepower. Maybe we should define the terms based on what the machine can do (to expand on MikePA's ideas). Can it handle a 5' brush hog with ease? Can it square-bale with ease? etc.
The "with ease" parts are the gray lines between the definitions.
When I bought my tractor I looked at what it could do for me and I didn't even know the terms CUT or SCUT.
This reminds me of the terms microcomputer, minicomputer, and mainframe or PDA, laptop, notebook, desktop or jump drive, pin drive, USB drive, thumb drive, memory stick, etc. Sheesh!
/ Define CUT? #10
thus my point about the second thing i consider most important is weight.
a 9n is what... double the weight of a rideing lawnmower aka SCUT.... certianlly not in the same class.
/ Define CUT? #11
For those machines with a 3pt hitch.. you can also figure in hitch class to hp and weight. IE.. cat 0 and limited cat 1 hitches for SCUT, cat 1 hitches for CUT, and cat 2 hitches for UT.. etc. Again.. not perfect.. but gives another level of definition. Add to that that you can use weight capacity of the 3pt as well as the hitch class. I have seen some small SCUT that manage to have a full cat 1 hitch due to geometry.. but due to size, hp, tractor weight, and hitch capacity can only lift 4' and smaller implements...etc
soundugy
/ Define CUT? #12
If I look at the Kubota line...B series and it's a SCUT, L series CUT. Except the 4400 overlaps the M series IMO.
But it really doesn't matter.
Rob
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
2019 FORD F-250 (A65643)
2019 FORD F-250...
2009 Case CX240B Excavator (A64194)
2009 Case CX240B...
2014 Kia Sorento SUV (A64557)
2014 Kia Sorento...
2020 Chevrolet Tahoe SUV (A64557)
2020 Chevrolet...
