Deere's New Pilot Controls
/ Deere's New Pilot Controls #1
gamble77
Georgia
Guys, here is a picture of Deere's new CT332 w/pilot controls. I know this isn't necessarily anything new to the industry but this is the first time Deere has had these available. They are available on all large frame SSL & CTL (325/328/332/CT332). They are EH controls, not wire contorlled. They have much better response then the CAT/ASV controls. I was in a Komatsu SSL this morning with pilot controls and it didn't have near the control while turning as the Deere machine does, same goes for CAT/ASV. Just thought some of you might like to see them and know they were out. Deere will also have forestry package/packages available by the end of the year...
/ Deere's New Pilot Controls #2
Whats new to me is that deere make YELLOW machines, I didnt realise they had different colors?
/ Deere's New Pilot Controls #3
Now, if Deere could only get the CTL ride selector out of bronco mode.
jmf
/ Deere's New Pilot Controls #5
Does the door roll up?
hnf
/ Deere's New Pilot Controls #6
Yes, the Door rolls up-that way if you run out of Fuel with the Boom up you can still get out, and you won't have issues with broken glass because either you bypassed the safety switch on the Door or forgot to close it-
/ Deere's New Pilot Controls #7
Yellow is construction equipment. Green is Ag. the Homeowner / Small acreage stuff rides on Ag's coattails.
/ Deere's New Pilot Controls #8
Hi Nate,
Is it an option or standard now. I would think they would make it standard since people are going that direction it would seem?
Maka
It is still an option, you can still get the standard hand/foot contorls, servo hand only controls (case controls), or the new EH Pilot controls.
/ Deere's New Pilot Controls #10
Nice. I think pilots are definitely the way to go.
I demoed a 332 not long ago with a snow blower and I liked the excavator door (it still had the old controls). I wish ASV would make all of their machines like that instead of just the SR70 & SR80.
Hopefully JD can increase their hydraulic hp. The RC100 has far superior hydraulic hp for those demanding high flow applications. My salesman showed me a chart that showed that the 332 was only putting out a little over 49 actual hydraulic hp (not the theoretical psiXflow/1714) at the attachment at 2750psi and only 10 actual hydraulic hp at 3300psi. The same chart showed the RC100 putting out 65 hydraulic hp at 3300psi at the attachment.
/ Deere's New Pilot Controls #11
All things being perfect I'd agree, but otherwise when it gets into slippery conditions and not perfect Case controls have an advantage when near stuck and with a foot throttle and two speed you can make short order of work.
Been stuck with the Gehl mechanical control and a electric pilot control and both times I felt if I was running the wheels I wouldn't have been stuck. Got to love ice!
