Deere/Yanmar 650 - Trying to Raise From the Grave
   / Deere/Yanmar 650 - Trying to Raise From the Grave #21
Is the pump timing established mechanically with shims? It is on the 950 but I don’t know about yours. When reinstalling the old pump you can usually get away with using the old shims but if installing a mew pump I would time according to the manual.
It is. I bought 2 new shims. Hopefully will be able to get this running in the next week or 2.
   / Deere/Yanmar 650 - Trying to Raise From the Grave #23
The shim kit usually includes shims of different thickness. Basically (as I remember) you want the number one port to start flowing at the start of injection mark on the crank. Probably better review the procedure for your machine. Also needed a test line to attach to that injection port.
UNUSED (2) 7000# DROP AXLES W/ BRAKES (A54756)
UNUSED (2) 7000#...
2002 VOLVO L150E WHEEL LOADER (A51246)
2002 VOLVO L150E...
MERCURY VERADO ENGINES (A55758)
MERCURY VERADO...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
2018 CATERPILLAR 299D2 XHP SKID STEER (A52705)
2018 CATERPILLAR...
2011 INTERNATIONAL DURASTAR 4300 M7 BUCKET TRUCK (A51406)
2011 INTERNATIONAL...
